Need Help 98 Codes
Old Mar 10, 2005 | 09:44 PM
camper's Avatar
camper
Default Need Help 98 Codes
Can someone help to define these codes and do I need to be concerned about them
AOLDCM-B2252H
B2206H
B2282H
B2284H
V1064H
A1RDCM-B2283H
B2285H
V1064H
A6SCM-V1160H
BORFA-C2120HC
help!!!!!
Old Mar 10, 2005 | 10:10 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
AOLDCM-B2252H
B2206H
B2282H
B2284H
V1064H
A1RDCM-B2283H
B2285H
V1064H
A6SCM-V1160H
BORFA-C2120HC
help!!!!!
AOLDCM is actually just LDCM or left door control module and the "H" means history, so no worries.
A1RDCM is right door control module, same thing no worries.
A6SCM is the seat control module again no worries.
BORFA is remote function (something, I forget :o ) and the code is current which is why it's followed by the "HC", this code means:
C2120 TPM System malfunction (No Sensors Received -TPM
so I take it your not seeing any tire pressure readings on the DIC.
Have you tried to do the relearn procedure?
David426's Avatar
David426
Click onto this link brother.. http://www.stengel.net/diccodes.htm Codes ending with H are history codes which may have occoured months or even years ago.. Good luck..
To Need Help 98 Codes
