I have LT's with cats and the Ti system. The sounder is slightly louder than stock, but by no means really loud. Bullets or Stingers will definitely be significantly louder than this setup.
I had headers, cats, and x-pipe installed and kept my Ti exhaust. Like you, I was really concerned about noise since I had a Borla Catback system on my last car and the drone was annoying. Happy to say that the increased volume is minimal at best. At WOT, the car seems much more throaty and aggressive, but I would not call it louder. I asked my wife if she noticed the difference and she stated that it sounded the same. My tuner also told me that I really didn't lose anything with the stock Z exhaust per the dyno (396 rwhp) as they were very surprised by the final hp numbers. I think you will be pleased in the fact that they don't add much volume for what you get in performance...
With all the above. I had 2 tip Stingers before my Ti's and no-cats.
It was brutal loud with the Borla's on. The rumble was awesome at the track and pulling up to rice, but it became very fatiguing after a while.
After the Ti's went on I got a great balance between good rumble and it is still quiet enough to talk to my passengers without concert type shouts.
Scott
Have the set up noted in the signature, nice purr under normal driving, aggressive sound @ WOT but not loud. (There is some valve train noise at cold start up.) Stock exhaust should sound like this, it's what a vette should sound like.
I have the setup in my signature. My wife didn't even notice, but from behind the car you can. She told me the tires were louder than the exhaust (run flats )
From: IF YOUR BIG DOLLAR PROJECT DOESN'T RUN 9'S OR BETTER ....BURN IT ! SHUT YOUR MOUTH AND GRAB A LANE ! CHICAGO IL. -------- HOME OF THE FASTEST STREETCARS BARNONE !
<---Kooks with no Cats and Stock TI Exhaust..It sounds good and it is not loud and obnoxious except that my car is Cam'n like crazy .
im putting on LT's,cam only car with stock Ti exhaust..should sound great.my buddy has x pipe cattless borla sounds like garbage even under 3 grand driving and has been known to cause headaches.made the mistake on my last car 03 cobra x pipe and stingers sounded like crap wot!
