I had my calipers off for a while to have them powder coated and the front brake lines did leak some but the master never went down. Now I went to drive the car and it has no brakes, I power bled them three times and it didn't help. I can pump them up with the car off and they seem solid, but as soon as I start the car they go to the floor. I can pump up while its running but they don't hold. Did I get air in the ABS? Is a Tech 2 the only way to bleed the ABS?
no codes, I do have a manual but didn't think any air got in the master, but I will try that next. Since my lines leaked a little and the master didn't go down do you think it went to the ABS first and got air in there?
I would suggest using a tech II to bleed the system. It sound likes air in the Master. Good luck !!
Tried bleeding one more time, still same thing but it did throw a code C1247. I'm gonna have to see if I can find someone with a tech 2 to come over and try and do it since I don't have enough brakes to drive it.
