Fuel Pump Install?
Old Mar 14, 2005 | 11:22 AM
Blown-Interceptor's Avatar
Blown-Interceptor
Default Fuel Pump Install?
Is there an easy way to change the fuel pump in my 98 Vette?
I had a 2000 Camaro and was able to cut a hole right on top of the fuel tank.
Does anyone know if I can do the same with my 98 Vette?
Thanks,
Jason
Old Mar 14, 2005 | 02:58 PM
gotjuice?'s Avatar
gotjuice?
St. Jude Donor '13
Default 98 fuel pump
Remove the drivers rear tire. The fuel pump is axcessed right there. You will see it-It's easy. Make sure it is almost out of fuel when you remove the pump assy. to avoid a mess.
Old Mar 14, 2005 | 03:35 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
WHY do you think that you need a new pump??? What have you done to eliminate everything elce that it could be??
Please let me know, I may be able to save you alot of time and money.
Bill C
Old Mar 14, 2005 | 04:44 PM
Blown-Interceptor
Bill C
I think I might need one because when I spray nitrous(125wet shot), I get a bad lean spike(15.2) as soon as I spray. Then it slowely goes to down to where it should be.
What else are you thinking?
Thanks,
Jason
Old Mar 14, 2005 | 04:45 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Thanks,
Jason
Fuel filter... This should be changed about every 10k to keep fuel pressure ideal.
You can also consider getting the NX acumulator. This will prevent draining the rails when spray.
Old Mar 14, 2005 | 07:11 PM
Blown-Interceptor
I don't think the fuel filter has been changed...I will start there.
I looked on Nitro Daves website for the acumulator, but could not find it?
Thanks,
To Fuel Pump Install?
