Header install problem
Old Mar 14, 2005 | 09:44 AM
jefsvet's Avatar
jefsvet
Default Header install problem
Hello while installing my new headers this weekend I think I may have cross-threaded a hole in the head.
I started the bolt in by hand and it went in a couple of turns, then while using a ratchet the bolt started to get tighter. I tried a different bolt and get the same results. What is the best way to fix this problem? Any help would be appreciated.
TIA
Jeff
Old Mar 14, 2005 | 11:07 AM
baddvette98's Avatar
baddvette98
go buy a tap set and pray!
Old Mar 14, 2005 | 11:33 AM
Mike04's Avatar
Mike04
Treat it with kid gloves after the tap.....
Old Mar 14, 2005 | 11:35 AM
George V's Avatar
George V
My bet is you did not strip it. I thought the same thing but it looks like GM used some lock tight that needs to be cleaned out. I used a cleaning tap by hand to clean out each hole before installing the new headers. Worked fine
Old Mar 14, 2005 | 11:39 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
tap set and clean the threads
Old Mar 14, 2005 | 03:04 PM
jefsvet's Avatar
jefsvet
Thanks for all the replies. I went out and bought a tap this morning and gave it a try. It appears the threads were okay, must have been the thread lock. Bolt went right in with no problems.
Should be back on the road shortly.
Thanks again, as always the forum members have come to the rescue!
Old Mar 14, 2005 | 03:17 PM
99SilverC5Coupe's Avatar
99SilverC5Coupe
I think the head is messed up.... now you have a valid reason for buying some AFR 205's and you might as well do a cam while your at it...labor saving expense...
Old Mar 14, 2005 | 03:41 PM
jefsvet's Avatar
jefsvet
That's what I was thinking as well. The wife might even by it considering all the cursing that was coming out of the garage yesterday!
Old Mar 15, 2005 | 11:26 AM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
lol...I used locktite instead of anti-seize on one header. Looks like first time the headers come off I'll be needing heads/cam. Oh crap.
At least that's what my lady will hear. "no, they can't get those LS1 heads anywhere"
To Header install problem
