Error Codes No idle
Old Mar 17, 2005 | 01:24 AM
ValiantSailor's Avatar
ValiantSailor
Default Error Codes No idle
I started my 04 Coupe this morning and it refused to idle correctly and would die. I drove it to town, and when giving it gas, it felt as though it had flamed out. The check engine light came on and the Dic code was P0106 and a bunch of B2284's. This translates to manifold pressure problem of some kind. Any way I drove the car back home and jumped in my error free *** mobile and went back to work. When I came home I started the Vette and everything is kewl. Running fine again. Can I reasonably expect the problem to come back or should I go see the clueless guys at Chevy?
Any help would be appreciated.
Old Mar 17, 2005 | 09:23 AM
iceburgh's Avatar
iceburgh
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05-'06-'07-'10
I have the same problem on occasions when it is cold ( under 30 degrees) It reads a misfire.... I dont I have not had any problems after started for a few minutes. Someone else might chime in but at this point I ma not worried about it.
Old Mar 17, 2005 | 11:42 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
TTT
Old Mar 17, 2005 | 11:59 AM
ValiantSailor
Im not sure what the popcorn box means but the C5 still has the problem. I tried it again today and same thing. Guess I will go see mr. Goodwrench and get it fixed. My concern was the problem going away totally. Goodwrench doesnt do so good on intermittant problems and with the dealer 60 miles a way I wanna know it going to get fixed cause it a half a day shot going and coming.
To Error Codes No idle
