How much torque on shocks
Top nut - 19 lb/ft to mounting plate.
Mounting plate - 22 lb/ft
Bottom bolt - 162 (that's right) lb/ft
Most torque wrenches only go to 150 so some estimation might be necessary.
Front:
Bottom bolts - 21 lb/ft
top nut - 19 lb/ft
Top nut is hard to do so you might just measure or count the threads before you take the old shock off and put it back with the same count.
Have fun. - C.
Lower Control Arm (Front) Cam Bolt Nut
145 N·m
107 lb ft
Lower Control Arm (Rear) Cam Bolt Nut
95 N·m
70 lb ft
Lower Control Arm Ball Joint Stud Nut (First Pass)
20 N·m
15 lb ft
Lower Control Arm Ball Joint Stud Nut (Second Pass)
3 ½ flats
Lower Control Arm Ball Joint Stud Nut (Final Pass)
70 N·m
52 lb ft
Outer Tie Rod End Stud Nut (First Pass)
20 N·m
15 lb ft
Outer Tie Rod End Stud Nut (Second Pass)
160 degrees
Outer Tie Rod End Stud Nut (Final Pass)
45 N·m
33 lb ft
Rear Crossmember Mounting Nuts (Use New Nuts)
110 N·m
81 lb ft
Rear Drive Axle Spindle Nut
160 N·m
118 lb ft
Rear Suspension Adjustment Link to Crossmember Nut
60 N·m
44 lb ft
Shock Absorber Lower Mounting Bolt
220 N·m
162 lb ft
Shock Absorber Upper Mounting Bolts
29.5 N·m
22 lb ft
Stabilizer Shaft Insulator (Lower) Clamp Nut
95 N·m
70 lb ft
Stabilizer Shaft Insulator (Upper) Clamp Bolt
65 N·m
49 lb ft
Stabilizer Shaft Link Nuts
72 N·m
53 lb ft
Tie Rod End Jam Nut
60 N·m
44 lb ft
Transverse Spring Mounting Bracket Bolts
62 N·m
46 lb ft
Upper Control Arm Ball Joint Stud Nut (First Pass)
20 N·m
15 lb ft
Upper Control Arm Ball Joint Stud Nut (Second Pass)
250 degrees
Upper Control Arm Ball Joint Stud Nut (Final Pass)
55 N·m
41 lb ft
Upper Control Arm Mounting Bolt
110 N·m
81 lb ft
Wheel Hub Mounting Bolts
130 N·m
96 lb ft
