too lean
Old Mar 19, 2005 | 10:33 AM
naturalgas's Avatar
naturalgas
Default too lean
ok had my baby dynod first pull unable to go pass 4500 14.8 afr whats up here only mods are vram borla cats even the guy at shop said he never seen a stock vet that lean sec. pull same thing went home ck fuel pressure 60 at idle stays there when given he gas just bought hp tuner o2 shows inthe 900 at full throttle what to ck next? thanks in advance
Old Mar 19, 2005 | 10:36 AM
Richin Chicago's Avatar
Richin Chicago
This may be too easy of an answer but my first dyno, also was quite lean. I disconnected the battery overnight and the next dyno pull (2 weeks later) was much better.
Old Mar 19, 2005 | 01:13 PM
fsuforever's Avatar
fsuforever
i wonder if u can add a fuel pressure regulator and jack up the pressure if that would help just a thought
Old Mar 19, 2005 | 05:32 PM
naturalgas's Avatar
naturalgas
my vet is an o1 i just got hp tuner so it won't be long before i can richen it if it's lean i don't think its that lean runs too good but if it is that lean don't want to hurt motor thanks for your help
Old Mar 19, 2005 | 05:44 PM
see5's Avatar
see5
If it was 14.8 at partial no probelm, but 14.8 @WOT and you need a good scan to figure it out. A battery reset will reset fuel trims but not likely change WOT AFR.
Old Mar 19, 2005 | 11:30 PM
99 vett babycar's Avatar
99 vett babycar
you might want to post this on "scan and tune"
Old Mar 20, 2005 | 03:00 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
If you have HPTuner and access to a dyno with a wide band then do some tuning, this condition is corrected under the "fuel control" tab and then click on the "power enrich" tab to change the PE table.
Old Mar 20, 2005 | 03:40 PM
leaftye's Avatar
leaftye
Naturalgas, I'd like to help you in the future, but I can barely comprehend your grammer. I'm sure I'm not the only one here that can't read your post. If you'd like our help, help us by taking the time to make a comprehensible post. The use of white space, punctuation and case goes a long way to making a post readable. If you can spell correctly, that's cool, but it's not a biggie. Try to avoid short cuts too. Using o1 and o2 in the same post is confusing, especially where they meant different things....like you meant o1=2001 and o2=oxygen^2.
To too lean
