Shortened shifter
Old Mar 19, 2005 | 12:06 PM
canadianguy's Avatar
canadianguy
Default Shortened shifter
Does anyone have that write-up about shortening the shifter about an inch?
Old Mar 19, 2005 | 12:17 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
I just bought a die the same size..9/16 I think....removed the ****...threaded the die down abount an inch..hacksawed it off..backed the die off...took 5 minutes
Old Mar 19, 2005 | 12:25 PM
canadianguy
How dangerous is it to do without the die? Do you like the new feel of your ****?
Old Mar 19, 2005 | 12:34 PM
pewter99's Avatar
pewter99
alot of people do without..I just figured it would allow me to "clean up" the threads
Old Mar 19, 2005 | 01:55 PM
03LingenfelterC5's Avatar
03LingenfelterC5
... Do you like the new feel of your ****?
Now that is getting personal...
Old Mar 19, 2005 | 02:15 PM
jers98vet's Avatar
jers98vet
He said ****
Old Mar 19, 2005 | 02:51 PM
randy ransome's Avatar
randy ransome
Winner 2020 C4 of the Year - Unmodified
2018 Corvette of Year
2017 C2 of Year Finalist
2015 C4 of Year
save yourself some time and buy a hurst, you won't believe the difference. I cut my shifter but it's still no comparison to the hurst, and only $200
Old Mar 19, 2005 | 04:24 PM
Derek Zalewski's Avatar
Derek Zalewski
There is not much to be gained by cutting the stock shifter. If you are looking for shorter throws and a more positve engagement... go with something aftermarket (Hurst, B&M, etc)
Old Mar 19, 2005 | 04:25 PM
Darion's Avatar
Darion
Old Mar 19, 2005 | 04:28 PM
JPEAK's Avatar
JPEAK
I drove one with cut down shifter, then with a Hurst. My vote is for the Hurst. No comparison!!
Old Mar 19, 2005 | 04:31 PM
JPEAK's Avatar
JPEAK
Hey canadianguy, Call Steve at Streamline Performance in Oakville. He should have some Hursts in stock. Good luck.
Old Mar 19, 2005 | 07:21 PM
vettenuts's Avatar
vettenuts
I bought the Hurst, installed it and hated it. Pulled it out a week later and sold it. I have been looking for another shifter, and with the positive reports on the C6 shifter which I have tried at the car show, I decided to get one of those instead. In the meantime, I did buy a stock shifter to cut down so I could keep my original.
Old Mar 19, 2005 | 10:38 PM
Avanti's Avatar
Avanti
I got a B&M, shortened (just hacksawed--LOTS of threads) it nearly an inch and dropped a 2.25" black cue ball completely down as low as it would go (just over 2").
With such large threads, you can cut without a die on the shaft--if the threads are long enough to begin with. If in doubt, just put on a nut the correct size--much cheaper than a die if all you are doing is just cleaning up the threads from a cut.
To Shortened shifter
