Battery Recommendation
Old Mar 20, 2005 | 11:39 AM
vettesniper's Avatar
vettesniper
Default Battery Recommendation
I think I need to replace the Delco battery in my 2002 Z06. Any recommendations?
Old Mar 20, 2005 | 12:11 PM
Devoz's Avatar
Devoz
No question, Hawker Odyssey PC925LMJT.
Old Mar 20, 2005 | 12:22 PM
Operations's Avatar
Operations
Will the OEM battery tiedown hold it or must we use a tiedown like yours?
Old Mar 20, 2005 | 03:16 PM
leaftye's Avatar
leaftye
OEM battery tiedown is just a wedge, so no, it won't work. You can easily make your own tie down out of some bar stock from Home Depot or Lowe's, and some long threaded bars.....or zip ties!
Operations, that's a nifty tie down. Where'd you get it? Please tell more about it. Is it metal or plastic?
Old Mar 20, 2005 | 05:14 PM
Devoz's Avatar
Devoz
No unfortunatly the factory holddown will not work with this battery. I did keep the factory tray, using I believe 12" J bolts and an adjustable plastic hold down. It works well, keeping the battery very secure, but I will probably fabricate something a little more visually appealing latter.
Old Mar 20, 2005 | 06:47 PM
DidntSettle's Avatar
DidntSettle
From: Manchester - Political correctness is tyranny with manners.
Optima red top...drops right in, and no leaking problems. Costco.
Old Mar 20, 2005 | 07:14 PM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
How much $ for the Odessey????
Old Mar 20, 2005 | 09:52 PM
Oldvetter's Avatar
Oldvetter
I went with Exide Orbital battery at SAMS Club, its a glass mat (gel) battery. Was $95, has best warrenty. I went with the smaller size, it still has more amps than OEM battery.
To Battery Recommendation
