A&A frame saver
Old Mar 20, 2005 | 12:08 PM
Sportsdude's Avatar
Sportsdude
Default A&A frame saver
Is it necessary to drill holes to mount or simply screw in without drilling?
Old Mar 20, 2005 | 12:34 PM
sempi's Avatar
sempi
You have to drill holes. No big deal. They make your life much easier. Well worth the minimal effort.
Sempi
Old Mar 20, 2005 | 12:44 PM
LS7 C5's Avatar
LS7 C5
GO to A&A website (see left column), click on Our Creations
then scroll down to Frame Savers. In that section click on
Actual Installation Pictures.
Old Mar 20, 2005 | 12:47 PM
Sportsdude's Avatar
Sportsdude
Thanks guys. I see where it said I have to use 3/16" inch bit but how deep? Would hate to drill a hole all the way through.
Old Mar 20, 2005 | 02:32 PM
leaftye's Avatar
leaftye
The metal is thin (thickness is in C5 General Sticky), you have to go all the way thru. You know it's a rectangular hydroformed tube right?? You'd have to have a monster drill bit to get thru the other side too! Just drill until you obviously get thru the first sheet, then pull out.
Old Mar 20, 2005 | 04:15 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
helped out englandgreen install these yesterday, takes < 1 hour, tap the holes all the way through, would've taken 10 min. but won't fit on my lift(the rails attach to were the lift posts would for the install)
Old Mar 20, 2005 | 04:29 PM
Sportsdude's Avatar
Sportsdude
Thank you leaftye and connecticut. The frame saver had been sitting in my storage for at least a year and half. I guess it's time to try and install.
Old Mar 22, 2005 | 08:17 PM
Bob Chapman's Avatar
Bob Chapman
I think that it has matured - go for it.
Old Mar 22, 2005 | 08:56 PM
C5FrankC5's Avatar
C5FrankC5
I used self-drilling screws. Didn't have to drill holes. Worked great.
Old Mar 23, 2005 | 11:49 AM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Actually, I looked at the screws before I drilled mine, and I used the next smallest sized drill bit; much better fit for the screws supplied.
Old Mar 23, 2005 | 09:14 PM
01Pewter's Avatar
01Pewter
CI 2-3-4-5-6-7-8-9-10 Vet
CI-X Auto-X Champ (street tires)
Cruise-In IX AutoX Winner
Frame Saver Installation
To A&A frame saver
