Dynatech Header Install Complete On 2k Coupe
removal-nothing new, just make sure the batt. is first
pass. side-rem. starter and have 2nd person hold against block below
rem. valver cover(3 min.)
header should drop right in from top
stay clear of a/c line near the firewall
drv. side
rem. grnd strap from engine block(one braided to frame/another goes to harness)
install from bottom
Install harness extesions before bolting headers up to heads and zip tie using brake line on drv. side and pass. side you will see two 1/2" holes in frame that can be used
Keep L and R O2 sensors to there respective sides(the header O2 bungs are indexed at 45deg and do not get crossed over like the aft o2 sensors)
this shouldn't take more than 1 hour for complete removal of stock system, and 3-5 for the install(1/2 for the headers the themselves, the rest of time spent on alignment, more alignment and routing the wire harnesses
any questions just run a thread or pm should have pics in a few days
Pix and here
http://forums.corvetteforum.com/show....php?t=1042951
EG
Pix and here
EG
A non scientific, non demonstrable "measure" of performance.
SOTP, "improvement" is usually most notable shortly after the modification is done and wanes when the next modification is being considered.
