I forgot!
Old Mar 20, 2005 | 05:11 PM
ROD BROWN's Avatar
ROD BROWN
Default I forgot!
Can anybody refresh my ,mind as how to reset the tire pressure monitors? I forgot the prcedure.
Old Mar 20, 2005 | 06:59 PM
Leo3's Avatar
Leo3
Default reset tire monitors
Try the following
Sensor Learning Procedure:
With the wheels mounted and the car on the ground:
Turn ignition to ON position.
Press the DIC RESET button to clear any warning messages.
Press the DIC OPTIONS button until the display goes blank.
Press and hold the DIC RESET button for 3 seconds.
Press the DIC OPTIONS button again until the "TIRE TRAINING" message appears.
Press the DIC RESET button until the message, "LEARN L FRONT TIRE" appears.
Hold the magnet(s) over the pressure sensor’s location on the LEFT FRONT wheel (this should be next to the valve stem sides if installed correctly).
When the horn honks, programming is complete for that wheel.
Program the other 3 wheel sensors as directed by the message display. The sequence is as follows: Left Front, Right Front, Right Rear, Left Rear.
For more information, refer to the Corvette Service Manual, page 3-114: Low Tire Pressure Sensing—TPM Sensor Programming.
Part Numbers: For '97-00 you'll need four each of the following: sensor numbers: sensor with O-ring PN 25731358; and retaining nut PN PN 10438853, retaining nut PN 10268439, and O-ring washer PN 10268438. These are the same for all four wheels.
In 2001, GM went to an FM bandwidth sensor, with the following part 25708165.
Hope this help.
Note: you will need a strong magnet.
Good Luck
Old Mar 20, 2005 | 07:21 PM
Leo3's Avatar
Leo3
You can look under "TECH TIPS" in C5. I you want to get to it quicker.
Old Mar 21, 2005 | 10:46 AM
ROD BROWN's Avatar
ROD BROWN
Default Thanks,guys
Thanks for the info.I totaly forgot how to reset the tire pressure sensors.It looks like (1) is dead,and I suspect it won't be long before the other (3) go out also.This could be anexpensive proposition.Oh,well its only money.
Old Mar 21, 2005 | 03:11 PM
L.A.P.D.'s Avatar
L.A.P.D.
Supporting Vendor
St. Jude Donor '03-'04-'05-'06
ROD BROWN,
Stop by one of these days and I will do it for you in a couple of minutes either with the Tech II or through the DIC.
Shawn
Old Mar 21, 2005 | 10:35 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Dead battery ????????????????????
To I forgot!
