comp r lifters
Mar 21, 2005 | 10:50 PM
St. Jude Donor '08
comp r lifters
need a new set of lifter stockers are pricey, are comp r good??????????
Mar 21, 2005 | 11:23 PM
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
I have them..they are tough lifters cant go wrong!
Mar 22, 2005 | 02:13 AM
i have them , and love them
Mar 22, 2005 | 02:57 AM
From: Sunny Earthquake Country, USA On the Left Coast (which is becoming more Right!)
Comp R's...
Quote:
When Andy put them in my engine he indicated that they may be more sensitive to initial adjustment than stockers and he put in Conp Pro Magnum SS adjustable 1.75 ratio roller tips and they seem fine and are relatively quiet.
Roy
Mar 22, 2005 | 03:26 AM
ya might as well get them since they are like 20 bucks more I think than the stock replacements
Mar 22, 2005 | 07:50 AM
I was told the Comp 875's (R's) are for use with adjustable
rockers arms...and they are very noisey.
The Comp 850's are good stock replacements.
If you decide on a new set of 850's, I have a new set I will
sell you cheap. E-mail me at
Scantech@bellsouth.net if
interested.
Good Luck!
Russ
Mar 22, 2005 | 10:42 AM
Don't run the Comp-R's unless your spring pressure requires them, or you are spinning over 7k.
They are sensitive to adjustment and will make your drivetrain noisy unless you have adjustable rockers and get them adjusted correctly.
Mar 22, 2005 | 06:05 PM
i have stock rockers, and i am running them torqued down to 20 ft-lbs, no problems here, a little noisey but your needing to run these, you have a big cam anyway so its going to be noisey anyway
Mar 22, 2005 | 06:47 PM
St. Jude Donor '03-'04-'05-'06-'07-'08
I have talked to Thunderracing tech and he told me the samething.
-Mike
