Solid Lifter adjustment
Old Mar 23, 2005 | 09:44 PM
blktie8's Avatar
blktie8
Default Need Help ! Solid Lifter rocker adjustment
When Number 1 is on the base circle I can set the lash
What other valves are on the base circle
move 90 and what valves are on base circle
Which pistons are at top dead center.
Its just not easy to get to the crank bolt to turn this motor
Does anybody have the top dead center info for adjusting solids with the ls1
Which valves are on the base circle for every 90 degrees or 180 or 270
Degrees.
I know I have read it, but I wasn't getting anything on the search.
If you can e-mail it
radio5@comcast.net
Old Mar 25, 2005 | 07:08 AM
blktie8's Avatar
blktie8
Still looking
Old Mar 25, 2005 | 12:35 PM
blktie8's Avatar
blktie8
to the top
To Solid Lifter adjustment
