Squeaking wheel
Old Mar 25, 2005 | 09:42 PM
MR Zip's Avatar
MR Zip
Cruising
Default Squeaking wheel
I have a 98 coupe that has developed a screech from the fan belt/water pump area of the engine which increases as rpm's rise. I suspect it might be the water pump. Only 46000 miles on the car. Has anyone haad any similar experience or are you aware that the water pump might go bad so soon?
Old Mar 25, 2005 | 09:58 PM
1NYCGUY's Avatar
1NYCGUY
I had a similar problem. It's most likely the Serpentine belt. You should go to Autozone and buy Gatorback belts. You may as well change the A/c belt while you're at it. The whole process should take 10 minutes.
Hope this helps.
Old Mar 28, 2005 | 06:29 AM
MR Zip's Avatar
MR Zip
Cruising
Thanks. I'll give it a try.
Old Mar 28, 2005 | 10:14 AM
Kenny94945's Avatar
Kenny94945
If it continues after the belt change, spray some water on the harmonic balancer and see if the squeak disappears.
Old Mar 28, 2005 | 10:18 AM
newgene's Avatar
newgene
I have had the same problem periodically, and a new belt always makes it go away. Does anyone have a preferred brand of serpentine belt that makes it go away for good? I just changed mine about 200 miles ago, and it has been gone since then. I assume it will come back in a few thousand miles, though. Any additional suggestions would be helpful.
Old Mar 28, 2005 | 10:45 AM
1NYCGUY's Avatar
1NYCGUY
Goodyear Gatorback Belts available at Autozone.
They seem to be the best.
Old Apr 2, 2005 | 10:11 PM
MR Zip's Avatar
MR Zip
Cruising
The new belts did the trick. Thanks.
Old Apr 2, 2005 | 10:16 PM
1NYCGUY's Avatar
1NYCGUY
Excellent,
That's good to hear.
Old Apr 3, 2005 | 01:23 AM
12stepvette's Avatar
12stepvette
St. Jude Donor '03-'04-'05-'06-'07
I had to replace both the Tensioner and Idler pulleys on the Accesory belt to get rid of my squeak.
To Squeaking wheel
