Left headlight (when closed) is not perfectly flush with hood...needs a slight adjustment. Looks like it can be done by loosening those 2 torx screws you see when hood is raised. Am i correct? If so...anyone know what size torx?
Thanks!
A forum member, who some of you might know(name left out for obvious reason) started adjusting his headlite door. Took him TWO days to get it back to a point were he was ok with it
they are actually t15 but there is 1 on each side that may need to be adjusted as well
Really? I only see the 2 small torx...one on top of the other....seems like those would be the only ones i'd need to loosen. I need to raise the inside part of left headlight cover...ever-so-slightly...to make it flush.
Thanks!
Just adjust the headlight by turning the black adjustment to move the headlight up or down ,the cover will move with it.
Remove the black plastic cover surrounding the light fixture and you will see two more torx screws, one on each side.
Yeah, actually there are 4 screws....Take the black plastic surround off to access them all if the **** adjustment doesn't work for you. Vol 3 chap 8 in the service manuals has all the details.
The headlight lids are quite easy to adjust if you understand how they work. Under the lid is an adjustment plate. This plate allows adjustment in all directions including rotation. It also has elevation adjustment screws on all four corners. To access this plate, remove the black mask, remove the four TORX screws holding the lid in place and lift it off. This will reveal the adjustment plate. It will take a few iteretions to get the lid where you want it.
Shirl
SDRE
