Wind noise on driver's side window...
Old Mar 26, 2005 | 06:09 PM
mdbennes's Avatar
mdbennes
Default Wind noise on driver's side window...
When Im on the highway around 70+ mph, bad wind noise...it doesn't seem like the window is getting a good seal...any tips on how to get a good seal? Thanks.
Old Mar 26, 2005 | 06:18 PM
Vrrooom's Avatar
Vrrooom
I've noticed on my car the seal tends to kinda bend a little into the window when it closes. Not sure how to fix it, I kinda held it in place while closing the door and it seemed to stay.
Old Mar 26, 2005 | 10:00 PM
RockyL32's Avatar
RockyL32
From: If your not the lead dog the view never changes Boise, Id
I had the same problem on my 2004. I mentioned it to the dealer when I brought it in for service and they adjusted the window
Old Mar 26, 2005 | 10:03 PM
djengr's Avatar
djengr
Default Door Window Tip-in adjustment
I told someone I would look at my service manual for this procedure then got busy, I can't remember who it was, anyway you might try this
from my 98 service manual (prelime). Curious are you having any water leaks into the car like when washing. Mine has a little wind noise noticable but not real bad. I took a little bit of foam weather strip from home depot and put a little in the fold of the door/window weather strip to push it out a little, took care of it.
Position window fully up
Remove the large access plug from under the front of the door
Loosen the window regulator front channl mounting nut.
remove the reflector from the trim panel
loosen the jack screw jam nut
Adjust tip in with the jack screw
turn the jack screw clockwise to tip the window outward
turn counterclock wise to tip inward
One turn of screw equals approx. 1 N-m (.04in) change at the top
of the window
Tighten the jack scew jam nut
Lower the window
Tighten the window regulator channel front mounting nut.
Raise the window and check alignment
Install plug under the front of the door.
Install the reflector.
Good luck
Old Mar 26, 2005 | 11:53 PM
ALLEGRO's Avatar
ALLEGRO
check up a minute!
I had this prob and found it to be that the seather stripping did not go "exactly" where it was supposed to after I reinstalled the top.
Big difference when I figure it out!
Hope that's it for you too.
Old Mar 27, 2005 | 08:56 AM
coast7's Avatar
coast7
Originally Posted by allegro
check up a minute!
Had to put the top back on 'cause it was raining...as soon as I drove it I heard wind noise above my head...not heard that before. When I got back to the garage I removed the top and saw the wx stripping at the corner, where it turns down from the top to the side, had torn, and was not seating properly with the top. Some super glue and all is well.
Never would have heard the wind noise before the sound proofing mod
Old Mar 27, 2005 | 12:19 PM
augydog's Avatar
augydog
St. Jude Donor '08-'09
Had the same problem, my fix was the windshield.
If your noise is coming near the front, this might help.
See my solution here:
http://www.z06vette.com/forums/showthread.php?t=78125
Good Luck.
augydog
To Wind noise on driver's side window...
