rear
Old Mar 26, 2005 | 08:32 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
Default rear
are the housings the same for a4 and m6
thanks
Old Mar 26, 2005 | 09:05 PM
Mike Mercury's Avatar
Mike Mercury
for the 3.15 and 3.42 ... yes.
The 2.73 carrier has a different housing.
Old Mar 27, 2005 | 12:22 AM
NICK YOSKIN
St. Jude Donor '08
MIKE if i have 2.73 and i buy complete rear(3.42 out of a m6) will it bolt right up to my a4 trans??
Old Mar 27, 2005 | 12:32 AM
1 Nasty Z's Avatar
1 Nasty Z
Been there and done that with a friends car last winter. Went from a 3.15 to a 3.42. No problems. Oh and he has a A4 and Diff was from an M12 tranny.
Old Mar 27, 2005 | 12:34 AM
1 Nasty Z's Avatar
1 Nasty Z
Oh sorry! missed your other question. I believe the housing is different only internally. Should bolt right up.
Old Mar 27, 2005 | 12:45 AM
NICK YOSKIN
St. Jude Donor '08
thanks aNYONE ELSE please
Old Mar 27, 2005 | 02:28 AM
griffgoody's Avatar
griffgoody
Hey guy's need help. I have a 98 auto vert which is in the shop getting 342's installed. This guy builds racing motor & trans but this is his first C5. He said that the 2 diff are both getrag's and they both look the same except from the front. He said something like that the 273 diff thats on my car is closed and has a lip in front and the 342 diff is open in front but will bolt up to trans. I called the forum member (TahoeC5)I bought it from and he said that he had it on his 98 auto vette and to call his mech dave at cci and talk to him about how he got it to work. But they were closed when I called. I think the guy that's putting it in is just a little spooked about the housings being different in front/ but, better safe than sorry. So, I guess what I need 2 know is---If the housing are different in the front but will bolt up 2 the trans--Will it Work. Hi Nick, I'll call ya later 2day. JOHN
Old Mar 27, 2005 | 08:33 AM
NICK YOSKIN
St. Jude Donor '08
[QUOTE=griffgood Hi Nick, I'll call ya later 2day. JOHN[/QUOTE]
cool
Old Mar 27, 2005 | 09:29 PM
griffgoody's Avatar
griffgoody
My mech said that "between" the shaft hole and the lip of the 342 diff at the bottom left, there's a hole about 3in long and about 1 or 2 inches wide and you can see the ring and pinion. And that where the shaft goes into the diff, there no place for a shaft seal, just a solid plate with a hole 4 tha shaft 2 go into. Does anyone know what he's talking about or is there some kinda plate needed 2 seal the hole. JOHN
Old Mar 28, 2005 | 12:18 AM
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
Yup!
Old Mar 28, 2005 | 01:21 AM
Mike Mercury
btu don't forget to tranfer over the "seal plate" from your A4 carrier to the oen removed from a manual shift. The manual shift setup doesn't use the seal plate.
and I see I didn't fully answer the original question:
The housings are different, exept on the one side where it bolts to the tranny... there thay are all the same.
They are interchangeable on all C5 platforms, but there are cosmetic exterior differences.
Old Mar 29, 2005 | 07:34 AM
NICK YOSKIN
St. Jude Donor '08
mike thanks!
trying to help a freind without seeing what he was reffering to sometimes is diffulcult. it had to do with seal plate
Old Mar 29, 2005 | 11:14 AM
Mike Mercury
Old Mar 29, 2005 | 05:32 PM
NICK YOSKIN
St. Jude Donor '08
nice!
john you paying attention!!! LOL
To rear
