MAJOR SMOKE at 76k??? HELP!!!
Old Mar 26, 2005 | 11:47 PM
MDriveMode's Avatar
MDriveMode
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Default MAJOR SMOKE at 76k??? HELP!!!
I went to look at an 2000 coupe today. Clean car, pacesetter headers , no cats, o2 simulators?, and some sort of SLP exhaust system. I think it was just SLP tips, got the car on the lift.. I had a buddy of mine drive it while following and noticed a sh*t load of blue/grey smoke at high RPM. From looking at the exhaust set-up: NO RESTRICTION! Have any of you seen anything like this?
Old Mar 26, 2005 | 11:53 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Run, don't walk, away from it.
Old Mar 27, 2005 | 12:02 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The intake tract could be loaded up with oil from the PCV Sys OR The rings could be weak/bad! Your pick!
BC
Old Mar 27, 2005 | 09:32 AM
RogueVette's Avatar
RogueVette
Cruise-In III Veteran
The Blue color is just gods way of saying get the hell out of there....Blue smoke is BAD!!
Old Mar 27, 2005 | 09:40 AM
Rob'sC5's Avatar
Rob'sC5
Cruise-In V Veteran
St. Jude's Donor '05
Runaway
Old Mar 27, 2005 | 10:45 AM
dpd's Avatar
dpd
blue/grey=bad.run for the hills,this car is hurt[internal engine,head/piston/etc].short and sweet,save your $$$$$$$.
Old Mar 27, 2005 | 11:03 AM
Black 00 Coup's Avatar
Black 00 Coup
STEP AWAY FROM CAR.....!
Old Mar 27, 2005 | 12:08 PM
jimcork1's Avatar
jimcork1
Default Leverage
Just figure out new crate engine + Installation Subtract from Selling price you would pay, This should give you a good ball park value given the "car" is ok.
Old Mar 27, 2005 | 12:20 PM
Goody's Avatar
Goody
Go find another car unless it is free.
Old Mar 27, 2005 | 01:15 PM
vetterlatethannever's Avatar
vetterlatethannever
And from your title 76k??
I think mine would smoke a 76,000 RPMs........
Just kidding!!! Seriously, keep looking!
Old Mar 27, 2005 | 02:53 PM
PHPD7102's Avatar
PHPD7102
St. Jude Donor '14-'15-'16
Another choice if the car is the right price is buying a take out motor like a few that are for sale in the parts section. Since it is smoking at 76k though I would go over the rest of the car with a fine tooth comb to make sure the rest wasnt abused as well.
Old Mar 27, 2005 | 06:36 PM
Jay-rod's Avatar
Jay-rod
Do a compression test if you are interested and find out for sure what the problem may be,76k is nothing for an ls1 it may be a bad pcv system ive heard of it before or it could be serious.
Old Mar 27, 2005 | 08:39 PM
03LingenfelterC5's Avatar
03LingenfelterC5
There is a documented issue with the #2 piston rings in LS1's but I cannot remember the date range, thought it ran up to 2001, but cannot remember when it started. Only looses oil at higher rmp since it is the #2 ring on the pistons. I am sure some one can link the document about this or at least name the dates of vehicles affected. GM has a fix "kit" to solve the problem, at least they did when it first started occuring.
Old Mar 27, 2005 | 09:23 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
True there is a TSB and it is NOT a recall. If your out of warranty,,,,YOUR PAYING FOR IT!
BC
Old Mar 27, 2005 | 11:33 PM
MDriveMode's Avatar
MDriveMode
Default Thanks!
Tomorrow, going back to do a compression test. This brain-dead idiot has diven this car everyday day for 2 years and never changed the plugs. MORON!!! I guess the exhaust was more important. Anyway, Thanks for everyone's 2 cents. I appreciate it.
Old Mar 28, 2005 | 12:14 PM
Ttop34's Avatar
Ttop34
Come on now, the car came with Platinum spark plugs, they are suppose to last 100,000 miles!!!
Old Mar 28, 2005 | 12:54 PM
vmspionage's Avatar
vmspionage
next time don't rev past 72k RPM
Old Mar 28, 2005 | 03:38 PM
GR8-LIFE's Avatar
GR8-LIFE
BC
GM, Unbelievable Thats why I said no to a C6.
Old Mar 28, 2005 | 05:11 PM
Red5's Avatar
Red5
FWIW: My green C5 did this. Like BAD. I thought the motor had blown or something...
Then you know what happened? It all cleared up and went away. All on its own. Never happened again.
To MAJOR SMOKE at 76k??? HELP!!!
