? about 99 fuel pressure....
Old Mar 27, 2005 | 05:41 PM
Assassin_808's Avatar
Assassin_808
Default ? about 99 fuel pressure....
I know the 99 has a fuel pressure regulator in the fuel filter cause I've had to change it... but I'm looking to get a high flow fuel pump and was going to get a fpr(fuel pres. reg.) for tuneing purposes, but if the stock regulator will keep up then that would save me another $140... so will I need the regulator or will the stocker keep the fuel press. at 60? any help on this subject would be great..
Old Mar 28, 2005 | 08:14 AM
Assassin_808
somebody has got to have a clue................. I need to make an order and would like to save the money...
Old Mar 28, 2005 | 09:02 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
you cant use an adjustable regulator on a 99 unless you change over the fuel rail system and return line to a 97/98 setup. If you are looking for more fuel you can add a Kenny bell boost a pump to your existing pump or aftermarket pump.
VR
To ? about 99 fuel pressure....
