Rear Brakes Question...
Old Mar 28, 2005 | 11:20 AM
mdbennes's Avatar
mdbennes
Default Rear Brakes Question...
I have changed out the front rotors and pads, and want to possibly do the rears. But I spoke to someone who said I might just need to get the rotors turned in the rear and maybe new pads....anyone have step by step instructions on the easiest way to do the rear brakes? Do I need to bleed the brakes if just doing the rear brakes? Suggestions please... thanks.
Old Mar 28, 2005 | 01:34 PM
mdbennes's Avatar
mdbennes
What do I torque the caliper bolts to? Thanks...
Old Mar 28, 2005 | 02:59 PM
Richin Chicago's Avatar
Richin Chicago
No need to do anything to the rear rotors unless they have some kind of problem. I never turn rotors any more when you can Raybestos Professional Grade for $20.00 each. www.rockauto.com
If you have done the front it should be no problem to do the rear. Same proceedure only a little easier as there is only 1 piston to compress. No need to bleed the brakes unless you have a soft pedal. The caliper bolts have a spec of 23 ft lbs. Make sure you grease the pins that the caliper bolts thread into.
Here is more info on pad changes:
http://member.newsguy.com/~rmoburg/j...eplacement.doc
And a picture of the caliper pins:
Old Mar 28, 2005 | 03:17 PM
mdbennes's Avatar
mdbennes
Great info...thats exactly what I was looking for...thanks again
To Rear Brakes Question...
