CV Boot Replacement...
Old Mar 28, 2005 | 07:27 PM
xlr8shn's Avatar
xlr8shn
Default CV Boot Replacement...
Anyone here replaced an inner cv boot on one of the back axles? If so, are there any howto's here? I have done a "search" and not really found any DIY stuff.
I've done a clutch replacement and recently a transmission swap in my 88k mile 99 M6.
Replacing the shocks now and see a dark cruddy grey/brown heavy weight oil around where the rear pass side cv boot is...
I had just replaced rear end and transmission fluids (rp gear max/gm synro mesh) and the stuff flung around that axle doesnt look as purdy as the newer fluids I just put in a week ago.
Old Mar 28, 2005 | 09:26 PM
Flareside's Avatar
Flareside
The boots are sealed, they don't mix with the differential lube. The dark gray/brown grease is that way from the factory, and it's not supposed to be changed (unless it leaks out).
I have a boot with a hole in it too, but I haven't tried to remove it yet. I just used a soldering iron to melt the hole closed instead. I have a boot kit on order now.
Old Mar 28, 2005 | 09:57 PM
xlr8shn's Avatar
xlr8shn
Thx Flareside... Didnt mean to conclude that the boots shared fluid with the rear or trans, just speaking out loud that I knew it wasnt royal purple (via a leaky side rear seal) or syncromesh from the M6. Pretty sure the boot is torn. Will double check tomorrow when I get back under the car.
In the past I've popped the half shafts from the diff, so I know I can get 1/2 of the rr axle out. Trying to determine what size socket is needed to get the outter side of the axle out, 34mm or 35mm. I'll go to Sears and purchase a couple of sockets and find out. Then I'll order new cv boot and the oil that is inside the boot...
Old Mar 29, 2005 | 10:59 AM
xlr8shn's Avatar
xlr8shn
ttt
Old Mar 29, 2005 | 01:11 PM
2kbluestreak's Avatar
2kbluestreak
Rear half shaft nut is 34mm. An 1 3/8" socket may also work.
Old Apr 1, 2005 | 02:09 AM
xlr8shn's Avatar
xlr8shn
rented a 34 mm socket from NAPA.
axle came out easy. rip on rr inner cv boot. ordered replacement from local dealer, Karl Chev here in iowegia
Old Apr 1, 2005 | 07:10 AM
gsxrjack's Avatar
gsxrjack
besides the 34mm axle nut, what else had to come off to get the axle out enough to change the boot..
thanks
jack
Old Apr 1, 2005 | 09:03 AM
xlr8shn's Avatar
xlr8shn
1) remove rear tire (obviously)
2) the two 18 mm bolts that connect the "A" upper control arm to car
3) the two 13 mm upper rear shock bolts
4) remove brake caliper: two 15mm bolts and use 16 mm wrench to keep the lil pistons from spinning when removing the 15 mm bolts... (I left the brake mount and the disc and hub on the car)
5) disconnect e-brake cable from behind rear hub and disconnect the wire connector that is next to the e-brake line at the rear hub.
I did NOT touch any of the ball joints.
Finally, pull the axle from the hub first (right after removing the 34 mm nut and soaking thread with WD40) then remove the back half of the axle from the differential... Came right out, no prob.
Old Apr 1, 2005 | 09:15 AM
Flareside's Avatar
Flareside
Have you changed the boot yet? That's the part that's got me worried. How do you get the new boot on, does the axle disassemble, and how do you deal with the crimp clamps?
Old Apr 1, 2005 | 10:27 AM
xlr8shn's Avatar
xlr8shn
The actual boot removal etc will occurr tonight when I get home from work. Not too sure of the proceedure but will post here what I find out.
I might take the half shaft and boot to the local Magic Muffler and get a pro's help and advice with clamp removal and whether the clamps can/should be reused, etc.
If anyone else has done this, boot removal/replacement seems easy enough, please speak up
To CV Boot Replacement...
