Down Shifting Problem
Old Mar 28, 2005 | 10:30 PM
sugarwolf's Avatar
sugarwolf
Default Down Shifting Problem
My 98 corvette m6 just started to do it, when i down shift from 3rd to 2nd it pops out of gear and slightly grinds somtimes but not all the time. Car has 50,000 miles on it. Wondering if its the Caggs sytem doing it since i havnt bypassed it yet or if there is a adjusment. Or am i gonna have to pull the tranny out.
Old Mar 28, 2005 | 10:56 PM
speedfreek155's Avatar
speedfreek155
Sounds like it could be synchros . At least that what it was in my B/W SuperT-10.
Old Mar 29, 2005 | 12:17 AM
sugarwolf's Avatar
sugarwolf
I dont think its syncros, it doesn't feel like its going all the way in gear. it doesnt grind when i shift it into that gear. It all happened after i rodded on the car and slammed it into 2nd and after that it only does it when i down shift from 3rd to 2nd .. any ideas?
Old Mar 29, 2005 | 01:56 AM
NLKoerner's Avatar
NLKoerner
Bent shift fork?
I have the same feel, dosen't quite feel like it is really in gear?
I am searching for the info to rebuild mine now.
Leaftye tells me the early trans has aluminum shift forks, so powering into gear could do it.
Rebuild @
http://www.ls2.com/forums/showthread...threadid=30484
Service manual @
http://www.ttcautomotive.com/English...ice_Manual.pdf
shows the rebuild.
Good luck
Norm K
Old Mar 29, 2005 | 11:38 AM
sugarwolf's Avatar
sugarwolf
Bent shift fork would be for 3rd and 4th gear, so i am gonna try the shifter adjustment first.
Old Mar 29, 2005 | 01:13 PM
sugarwolf's Avatar
sugarwolf
Adjusted the shifter and it fixed it! seems it just moved a hair just enough to not let the tranny fully go in gear.
Old Mar 30, 2005 | 01:11 AM
NLKoerner's Avatar
NLKoerner
SO glad you got it fixed.
You have 3 shift forks in your trans,
1st & 2nd pn 12523210
3rd & 4th pn 12523207
5th & 6th is called a lever, pn 12523204
I only wish my fix was as easy as yours.
Always take the easy fix first.
Norm K
Old Mar 30, 2005 | 08:27 AM
rodney@rpmtransmissions's Avatar
0rodney@rpmtransmissions
Former Vendor
Actually 4 forks,You forgot the reverse fork.
Old Mar 30, 2005 | 12:10 PM
NLKoerner's Avatar
NLKoerner
You'r right.
I wasen't thinking too clearly.
Norm K
To Down Shifting Problem
