High Flow Cats... Please Help
Old Mar 29, 2005 | 07:28 PM
MDriveMode's Avatar
MDriveMode
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Default High Flow Cats... Please Help
What are the best cats to buy for a c5 and where? Will I notice an increase over the stock cats?
I'm running stock manifolds, a Magnaflow X-PIPE, and B&B Bulletts on an 01 Coupe if that helps.
Old Mar 29, 2005 | 07:35 PM
AVB's Avatar
AVB
The buck seems to stop at Random Techs.. their a bit pricey and as an alternative the dynatech powercats have been mentioned as identical and less $$$'s.
Call West Coast Corvettes and ask for Paul, if you're also looking for an x-pipe.. mention the tpis xpipe and cat combo and you wont be sorry..
Old Mar 29, 2005 | 07:43 PM
WildWolf's Avatar
WildWolf
I don't think they will give you much power unless they are mated to some long tubes. My $0.02
Old Mar 29, 2005 | 07:54 PM
AVB's Avatar
AVB
Oops.. didn't see you had the magna's already...
Old Mar 29, 2005 | 08:43 PM
MDriveMode's Avatar
MDriveMode
Headers with the bullet exhaust, that would sound like a NASCAR race!!
Old Mar 30, 2005 | 01:05 PM
Jeff Jeff's Avatar
Jeff Jeff
They will change your exhaust note some, but I would not expect much HP gain on a stock engine.
Old Mar 30, 2005 | 01:12 PM
AU N EGL's Avatar
AU N EGL
TPIS Long tubes with Random Tech High flow cats and x-pipe with GHL exhaust.
all of these , long tubes, high flow cats. high flow x-pipe and good exhaust are needed for additional power. adding only one or two realy wont give much more HP.
Then better air intake and of course the dyno tune to make it all work together. piece meal dosnt do much
Good Luck
Old Mar 31, 2005 | 05:37 PM
vetred's Avatar
vetred
Default Best Hi-flow cats??
There is, finely,..... a great selection of good hi-flo cats out there as far as the best? "Different cats, for different strokes"Although,...the Bassini Hi-flow cats won the award at the Las Vegas S.E.M.A. show
Old Mar 31, 2005 | 06:05 PM
Rag-Top Rick's Avatar
Rag-Top Rick
I`m running QTP`s w/Random Tech cats/x-pipe and B&B Bullets.
I`ve been told it sounds like "a Ferrari on steroids!"
The sound of music!
Cheers, Rick
To High Flow Cats... Please Help
