WTF is broken?
Old Mar 30, 2005 | 10:53 PM
Prosecutor's Avatar
Prosecutor
Default WTF is broken?
Alright guys...time to help out the less mechanically inclined. I opened my hood today and found something hanging. I don't know what it does or where it plugs into...let me describe:
The piece is a plastic coated wire that comes out from beneath the hoodliner on the bottom (near where the hood hinges), and there is a plastic connection on the loose end. It looks like it plugs into something. Any idea what this is? How could it have come undone...where do I plug this back into? Probably not a big deal...but driving me nuts. I would post a pic if I had a digital.
I can't imagine what need a connection behind the hoodliner.
Thanks in advance.
Old Mar 30, 2005 | 10:57 PM
Lithium's Avatar
Lithium
I'm pretty sure this is the wire that connects to the radiator shroud on the far right side(looking from the cab) about half way down. If I am wrong I am sure someone will chime it, but if we are thinking of the same wire that thats where it goes. Good luck
--Marc
Old Mar 30, 2005 | 11:01 PM
Prosecutor's Avatar
Prosecutor
I guess you are correct. Thanks. I found the "female" connection the wire plugged into. What does this do? and why does it go up under the hoodliner? Thanks.
It plugged into a wire that comes up from beneath the big black piece with the "rubber bumber" that supports the front of the hood. Geez, I sound like a third grader...but I don't know what this stuff is.
I really appreciate the help.
Old Mar 30, 2005 | 11:27 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
It's actually the wiring for the hood light.. To verify, unplug it and your hood light should go out!
Old Mar 30, 2005 | 11:53 PM
Prosecutor's Avatar
Prosecutor
Oh man...I didn't know I had a hood light. Damn thing must have been unplugged since I bought the car.
Old Mar 31, 2005 | 04:15 PM
Lithium's Avatar
Lithium
Glad it helped!
--Marc
Old Mar 31, 2005 | 04:28 PM
SPD FRK's Avatar
SPD FRK
I keep mine unplugged so as not to run the battery down at car show's. I know it will switch itself off after about 10 min but...
Old Mar 31, 2005 | 04:47 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Old Mar 31, 2005 | 05:37 PM
BlackMagicC5's Avatar
BlackMagicC5
Thats odd, I'm pretty sure mine was unplugged when I bought the car too. I just left it unplugged since my car spends a lot of time with the hood open.
Old Mar 31, 2005 | 07:23 PM
JH's Avatar
JH
Prosecutor, monitor your car's state of charge carefully. I wonder if that hood light was disconnected for a reason!
Old Mar 31, 2005 | 09:25 PM
DDSLT5's Avatar
DDSLT5
Maybe because the hood was up a lot, and the moron who owned the car before didn't know it shuts off automatically after a few minutes?
Old Mar 31, 2005 | 09:28 PM
ALLEGRO's Avatar
ALLEGRO
BINGO
Old Mar 31, 2005 | 09:44 PM
RonJ's Avatar
RonJ
If the hood is up and the light is auto off, I believe it will come back on if someone opens the door ..... not a good deal if you are showing your car all day.
I'm one of the many morons who disconnect the hood light ...
Ron ...
Old Apr 1, 2005 | 12:16 AM
Prosecutor's Avatar
Prosecutor
Thanks for the tip. If there is a problem like that, I will have the dealer correct it.
To WTF is broken?
