Arrrrrrrrrrrrrrghhhhhhhhhhhhh steering column lock keeps...
Old Mar 31, 2005 | 01:23 AM
My2Dogs's Avatar
My2Dogs
Default Arrrrrrrrrrrrrrghhhhhhhhhhhhh steering column lock keeps...
...........coming on in the DIC. Car has been idle for 3 weeks and now everytime I start it I get the "Service steering lock"
I had the the lock crap replaced about 3 months ago.
Any help out there ?
Old Mar 31, 2005 | 01:34 AM
vetred's Avatar
vetred
Default steering lock crap...............
this is probably the most well know recall dealing with this issue.........if this wasnt fixed by your local dealer then it was supposed to be!
Old Mar 31, 2005 | 02:02 AM
Cscokd's Avatar
Cscokd
if your car has been idle for three weeks, make sure your battery is good and fully charged...install a CLB... and read the sticky at the top of the tech section. Good luck.
Old Mar 31, 2005 | 10:11 AM
shaneotool's Avatar
shaneotool
I get the "service column lock" message on the DIC everytime I start my car since yesterday. It just popped on the screen while I was driving - now it won't go off. But nothing seems to be wrong with my column - it drives fine. I bought the car used about a month ago. Has this happened to any one else?
Old Mar 31, 2005 | 10:42 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
Was the Sticky thread at the beginning of this forum no help?
Old Mar 31, 2005 | 10:44 AM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
put mine in as soon as the CL started acting up.
Old Mar 31, 2005 | 11:57 PM
Grand Slam's Avatar
Grand Slam
Mine came on after some work in the shop. I assumed it had failed but ignored it. The next time it came back from the shop it was ok again. You might try disconnecting the batter and see if that resets it. If you do, make sure you have the radio security code in case you need it (I didn't).
To Arrrrrrrrrrrrrrghhhhhhhhhhhhh steering column lock keeps...
