replacing air check valve
it seems like that bolt is almost impossible to get at.... i've read that these valves clog up.... while i had both sides of the tube unhooked i tried to blow thru it.. it was clogged but i gave it a quick shot with my air compressor now its free flowing,,, i'm hoping that'll cure it...
1. The PCM turns the pump on when the car is started. The PCM samples the O2 sensors and looks for a change in O2 reading when the pump is running. When the pump is turned off the PCM looks for the O2 readings to returm to normal.
2. Is the pump really running? If it is, is it pumping air?? There is a vacuum operated diverter valve on the pump. The vacuum is supplied to a control valve which is located in the passengers fender well just aft of the PCM/TAC module. The vacuum supply comes from the rear of the intake manifold: Red circle:
From there it goes to a vacuum resoviour in the passengers fender well area. The resovior supplies the HVAC System and the AIR Diverter Valve vacuum. Is the dirverter valve on the AIR Pump working and have the correct vacuum??
I would remove the supply hose on the air check valve and see if there is good air flow when the pump is running!.
Here is the rubber hose and the flange on the other side:
The AIR pump is in the drivers front fender, just forward of the front tire. You will need to jack up the front of the car, remove the closeout cover onder the fender and the pump is right there. Also make sure all of your hoses are in good shape. The area where they pass by the alternator is VERY tight and can rub through the hose.
Bill C
Robert
I will do the test and get back to you>
Bill C
