FRC-Noisier than regular coupes?
Old Apr 1, 2005 | 10:34 PM
meadowz06's Avatar
meadowz06
St. Jude Donor '09 and '13
Default FRC-Noisier than regular coupes?
I just took possession of a 2000 FRC with 18000 miles.It seems to have
alot more road noise than my previous C5 coupe. What is the reason?
The car has Yokohama tires, not the Goodyear run flats. What is the deal? I love the car, but it does seem a bit noisy, and it gets louder as speeds increase.To me it sounds like the rear end.
Old Apr 1, 2005 | 11:17 PM
Scubanme's Avatar
Scubanme
I understand that FRCs are lighter in weight than C-5 coupes. Thinner windshields, less insulations lighter seats, etc.
Old Apr 2, 2005 | 09:02 PM
Dope's Avatar
Dope
Resident moron
Assuming everything to be equal, I don't think the FRC is louder. The tires could be the deciding factor. Or it could have a problem.
Dope
Old Apr 2, 2005 | 09:16 PM
BLKDOUT's Avatar
BLKDOUT
I do agree that my FRC is louder than my dad's Coupe. My younger brother also says the same thing and he frequently rides in both cars.
Old Apr 2, 2005 | 10:08 PM
LoneStarFRC's Avatar
LoneStarFRC
Hardtops are known for this. I removed all my rear carpeting and made liberal use of Dyna-Mat. I used the thicker stuff on the horizontal surfaces (3/16"?) and the 1/6" stuff on the vertical surfaces. I also installed a separator panel. This made a very big difference. HTH
Robert
Old Apr 2, 2005 | 11:18 PM
meadowz06's Avatar
meadowz06
I don't think the car has any mechanical problems. It only has 18000 miles on the clock and drives very good. My coupe was not this loud though. I think it must have something to do with the body style and lighter weight. I am ordering the partition very soon.
Thanks for the replies.
Old Apr 3, 2005 | 01:52 AM
silkywilson's Avatar
silkywilson
I can only say my Z06 (FRC) is loud simply because of lack of sound deadening material. I dont know if the regular FRCs had the lack of sound deadening as the Z06 does but I would expect it got the same treatment for weight savings..
Old Apr 3, 2005 | 07:20 AM
AFVETTE's Avatar
AFVETTE
Here's what's under your carpet in an FRC/Z06:
You can add a trunk partition like this
Or go the next step and add some DynaMat like this:
After these two mods my modded Z06 is quieter than my 99 coupe.
For what it's worth here's what GM has to say on this issue:
Quote - Acoustic package revised to reduce weight and allow more aural feedback of the powertrain - Unquote
Tom
Old Apr 3, 2005 | 11:42 AM
meadowz06's Avatar
meadowz06
Tom,
Great post. I really appreciate the detailed information. I am ordering the partition, and you are right, my coupe was not near as noisy.The car is in such excellant shape with such low mileage, I did not think anything was wrong. I just wanted to make sure.
Thanks again.
Old Apr 3, 2005 | 02:54 PM
Izover4u's Avatar
Izover4u
Tom
How much did the dynomat cost you? How much weight did it add? I am thinking about doing the dynamat/frostking or just the insulation in
wheel wells
Wayne
Old Apr 3, 2005 | 03:17 PM
I brake for nothing's Avatar
I brake for nothing
It would be lighter to add the partition or make one up, dynamat is heavy
Old Apr 3, 2005 | 04:29 PM
mdhmi's Avatar
mdhmi
The added weight from the Dynamat is hardly going to cause a performance loss.
Cheers,
Mark
To FRC-Noisier than regular coupes?
