Ready for 1st Mod's ??? What do you think?
Old Apr 3, 2005 | 01:04 PM
scottyo's Avatar
scottyo
Default Ready for 1st Mod's ??? What do you think?
New guy here,
I have a 2004 convertible 6 speed that I do not take to the track and have no plans to in the future. Just cruise and some fooling around on the street. When the GM warranty expires I plan on a H/C, nothing too radical.
Right now I am ready to pull the trigger on the following:
Blackwing (power adder?)
Dynatech Supremaxx including high flow cats and X pipe (power adder?)
Corsa exhaust (no power adder, looks and sound only?)
I am looking at the Dynatech because I want to continue to use the rear O2's and do not plan to change the computer tuning until I do the head and cam after the GM warranty expires.
Am hoping these 1st mods will wake up the car and be a good starting point for the H/C down the road.
Your thoughts and input please.
Many Thanks
Old Apr 3, 2005 | 01:26 PM
BAD_TCR's Avatar
BAD_TCR
Welcome. And your ideas look good for starts. I'm just starting out too on the mods, and have basically everything you are going to be adding. You are correct on which mods will bring your power vs sound. Good luck. Those are some good first mods, that will only get you in the mood for more. Now, if only my checkbook had more mood...
Old Apr 3, 2005 | 01:37 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You might want to consider Stainless Works headers! I got their complete system for my 02 Z06 and I am VERY VERY happy with it! It too has provisions for BOTH front and rear O2 sensors, has plenty of room for the stock spark with shields, excellent workmanship and I get very little in cabin resonance!
The exhaust on the Z is a 1 3/4" primary tube with 3" collectors, 3" mid section with X pipe, Random tech high flow cats and duel outlet Stainless Works exhaust!
Here ars a few pics.
It is not too loud, It has a good rumble at idle, excellent part throttle grawl and rocks at WOT.
If you lived close I would give you a test ride!
I gave Englandgreen one and he was IMPRESSED!
BC
Old Apr 3, 2005 | 01:41 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Sounds like a good plan. If you added 4.10 gears, you would wake it up big-time!
Old Apr 3, 2005 | 01:47 PM
Icemanskis's Avatar
Icemanskis
Cruise-In VI Veteran
St. Jude Donor '05
Yep, your first mods look good. The dynatechs are a good brand of headers. They are much easier to install than other brands and keep all four 02 sensors. I have them and the increased sound is great, but I wasnt overly impressed with the performance. I gained nothing from the headers alone and only 9rwhp and 17rwtq with a tune. But money was an issue for me. Another ten horsepower wasnt worth 600 bucks to get the LGs. If you have money to spend and are not constrained I would recommend the LGs. Get some O2 simulators and get a tune. If you do a heads/cam later on you can re-tune for a nominal cost. My original tune was 550 bucks and then 100 for each additional tune. The blackwing is a good substitute for the stock airbox, I have one as well. Easy installation, no problems.
Old Apr 3, 2005 | 04:27 PM
mdhmi's Avatar
mdhmi
I ran a Blackwing along with the Dynatech headers a few combos ago. It ran wonderfully and I didn't need to retune the car after adding the headers.
Cheers,
Mark
Old Apr 3, 2005 | 11:20 PM
Dark-Knight's Avatar
Dark-Knight
Check with your dealer before the mods in case tehy say the mods will void warranty. My '04 has dealer approved mods, see sig...
Old Apr 4, 2005 | 12:28 AM
Mitch C's Avatar
Mitch C
Old Apr 4, 2005 | 11:54 AM
scottyo's Avatar
scottyo
Default Any more ideas???
Thanks for the input to date. Any more ideas from you experienced guys?
To Ready for 1st Mod's ??? What do you think?
