Kooks header air tube problem
Old Apr 4, 2005 | 10:16 AM
JSTAN's Avatar
JSTAN
Default Kooks header air tube problem
Hello
I just installed a set of Kooks LT's. The problem I am having is the passengers side header air tube does not mate with the air tube in the engine. Has anyone else run into this problem?
My guess would to heat the air tube from the engine and bend it to fit the air tube on the header.
Any advice is appreciated.
Old Apr 4, 2005 | 10:36 AM
ragtopws6's Avatar
ragtopws6
You might have the wrong year headers. They have 97-00 and 01-04 I think.
Old Apr 4, 2005 | 11:14 AM
JSTAN's Avatar
JSTAN
I believe I have the correct year. The air tubes are off by about 1/4". If they were off my more I would agree with ya.
Old Apr 4, 2005 | 12:31 PM
Avanti's Avatar
Avanti
Off a quarter inch? Sheesh!
Old Apr 4, 2005 | 12:32 PM
vettenuts's Avatar
vettenuts
I found mine was off slightly when I did my installation. I held the tube and carefully bent it to fit exactly so there wouldn't be a load on the welded fitting of the header. The tube is actually pretty bendable if you don't go crazy.
To Kooks header air tube problem
