Help with codes
Old Apr 4, 2005 | 04:37 PM
JohnTheStigGalt's Avatar
JohnTheStigGalt
Default Help with codes
Ok guys, on startup, I get the following messages:
"Service Traction System"
"Service ABS"
"Service Active Handling"
A check of the codes reveals this:
28-TCS C1214 H C - "Sol Valve relay contact or coil ckt open"
99-HVAC B0338 H C - "Inside Air temp sensor open"
For the love of GOD, what's it all mean???!!!
Old Apr 4, 2005 | 04:39 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
well TCS is Traction control system...other one is A/C....did you reset them and they come back??
Old Apr 4, 2005 | 04:40 PM
pewter99's Avatar
pewter99
also...http://forums.corvetteforum.com/show....php?t=1055970
discussed here
Old Apr 4, 2005 | 04:45 PM
JohnTheStigGalt
Yes, I reset them, and they both came back. The other post is what prompted this one, since it doesn't cover that particular code for the TCS... I'm getting the same messages, just a different code...
Do you know if "open" means the circuit is open, i.e. not functioning?
Thanks!
Vaughn
Old Apr 4, 2005 | 04:47 PM
pewter99's Avatar
pewter99
Thanks!
Vaughn
Man....I am not that well versed...get with Bill Curlee..he is the forum electrical guru...
I would venture to say "yes"....but like I said...Patches also may have some input
Old Apr 4, 2005 | 04:56 PM
pewter99's Avatar
pewter99
I went and looked in my service manual...it describes the problem as an "open or short to ground" possible corrosion etc...loose connection with the module...
Old Apr 5, 2005 | 03:48 PM
JohnTheStigGalt
Thanks, I'll see if I can find a loose connection... Maybe when I put the aluminum gauge trim rings in, I didn't fully seat the button, and it took a little while to work loose...
Cheers,
Vaughn
Old Apr 5, 2005 | 05:06 PM
2003vert's Avatar
2003vert
can't speek to the codes but in electrical talk OPEN means that there is no electrial connection to the device that the computer can find. Or in other words there is a short to ground preventing the conneciton or the wire that it wants to use is not connected " open " hope this helps.
To Help with codes
