LS1 oilpump prime?
Old Apr 5, 2005 | 07:33 PM
sweet97c5's Avatar
sweet97c5
Default LS1 oilpump prime?
Installed motor,no oil pressure.Can oil pump be primed?
Old Apr 5, 2005 | 11:28 PM
FRCTony's Avatar
FRCTony
Default Are you sure there is oil in it :)
1. Disconnect coil packs
2. Crank until you get pressure
Hope it is O.K.
Old Apr 6, 2005 | 04:56 AM
vettenuts's Avatar
vettenuts
Someone on LS1Tech had the same problem a few months ago, you might want to do a search over there. I always wondered if you could pull a vacuum at the oil filter and draw the oil into the system with something like a Miti-Vac and some creative plumbing.
To LS1 oilpump prime?
