Where Did You Put Your Shift Light?
Old Apr 7, 2005 | 12:33 AM
2MuchRiceMakesMeSick's Avatar
Default Where Did You Put Your Shift Light?
Lets see pics of your shift light.
Anyone put one in the center vent?
Old Apr 7, 2005 | 03:56 PM
Patches's Avatar
Patches
A few guys here have installed it in the center vent but none of them said it was easy.
I made a custom mount to fit in my A-pillar pod when I installed my wideband.
Old Apr 7, 2005 | 04:28 PM
slo-vette's Avatar
slo-vette
No pictures but I've put mine on the A-pillar with velcro. I change my shift points to often to mount it in the center vent. I bet it would look slick though.
Old Apr 7, 2005 | 04:50 PM
ROJO99's Avatar
ROJO99
Half way up the "A" pillar with two sided tape here. Sorry no picks.
Old Apr 7, 2005 | 04:51 PM
Thats the only problem really. Advantage is that it would be totally hidden
Old Apr 7, 2005 | 04:53 PM
mdhmi's Avatar
mdhmi
On my A-pillar. Check my profile for link to CarDomain pics.
Cheers,
Mark
Old Apr 7, 2005 | 05:02 PM
Assassin_808's Avatar
Assassin_808
not sure if these will show up.... but I put a quicklite on my steering column and the view is just to the left of the display so all the gauges and warning lights are still visible and the moduel in the glove box....
Old Apr 7, 2005 | 11:11 PM
tlaselva's Avatar
tlaselva
On the A pillar, right at eye level.....
You really can't see them from the outside. The darkened top part of the windshield hides them nicely.
Old Apr 7, 2005 | 11:50 PM
SpeedyZ's Avatar
SpeedyZ
I put one in my HUD on my 01 Z06. It is triggered my the factory "SHIFT" indicator in the HUD. Cost was around $4.00. 100% hidden!
Old Apr 7, 2005 | 11:58 PM
atz06's Avatar
atz06
Hey SpeedZ, would you shar with us how to do it? I like it a lot
Old Apr 8, 2005 | 12:03 AM
xtream1's Avatar
xtream1
From: Stealth So Cal GOCC ...comming to invade your neighborhood soon
This one takes the prize. PLEASE tell us more!
Old Apr 8, 2005 | 12:27 AM
RobWilson's Avatar
RobWilson
Mine is in the center vent. I'll see if I can get some pics uploaded and posted.
Old Apr 8, 2005 | 09:43 AM
RobWilson's Avatar
RobWilson
I uploaded the pics and they have been approved now. Click on "My Corvette Photos" in the left column for two pics from the shift light install.
Old Apr 8, 2005 | 11:21 AM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Can you adjust your rpm shift points with this setup? If so, I like it! Really cool!
Old Apr 8, 2005 | 03:17 PM
SpeedyZ's Avatar
SpeedyZ
Yes, I had planned on doing a write up on this once I got it all done (the car done), took lots of photos while building the project. It was fairly simple to make it work and should be pretty easy to duplicate. It does run under microprocessor control! Which is over kill but the easiest way to make it work. The problem I had was sensing the factory SHIFT segment. The HUD segments are pulsed about 250Hz and the pulse width is varied for brightness. When the display is set down dim the pulse width it only 5us wide making it hard to detect. So I went with a microprocessor and interrupt control. Chip cost is around $2 and around 25 lines of code.
GM should have been able to do this for less than $.25 per unit! Makes you wonder sometimes...
I honestly don't know. I have not drove with this setup yet, I only have 80% of a car right now. I think the factory SHIFT indicator is controlled by the PCM and I think it can be programmed in the PCM. There is a "Shift light" RPM setting in the LS1-Edit that I looked at but I have not found anyone that can tell me if that does in fact control the SHIFT light. Anyone out there doing their own programming that could check this? I'm hoping I can change it in the PCM.
Old Apr 8, 2005 | 04:08 PM
C5-JIM's Avatar
C5-JIM
I attached mine to the drivers side of the rear view mirrow with the wire coming down from the windsheld molding. I have a Harland shift lite. At that location it lites the drivers side up real nice without taking your eyes off the road.
Hope this helps.
JIM
To Where Did You Put Your Shift Light?
