Hazard Light Switch Replacement
Old Apr 7, 2005 | 01:35 PM
One Blue Vette's Avatar
One Blue Vette
Default Hazard Light Switch Replacement
How dificult is it to replace the switch?
I do know that the dash has to come out to get to it.
What would the dealer charge for this job?
Old Apr 7, 2005 | 01:43 PM
JeepTJ's Avatar
JeepTJ
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
I need to do mine too. But I will not take the car to the dealer.
Someone said you could get to it from behind the radio.
Old Apr 7, 2005 | 10:06 PM
Vettlldo's Avatar
Vettlldo
Ehhh...and the hazard signal needs replacing because? Is it used as the turn signal switch?
Old Apr 7, 2005 | 10:56 PM
LoneStarFRC's Avatar
LoneStarFRC
Yup. Actually it is not the switch per se, but rather the flasher for both the turn signal and the hazard lights. There are a couple of How-To's for doing a HUD install and the directions for removing the dashpad are very helpful. Once the dashpad is off, getting to the switch assembly is pretty easy.
JeepTJ: I know of no way to get to this from behind the radio. I explored this myself and no go.
Old Apr 7, 2005 | 11:02 PM
Admiral Fairway's Avatar
Admiral Fairway
There was a thread posted before where someone changed the flasher without removing the dashpad. Try doing a search.
Old Apr 8, 2005 | 12:14 AM
flash134's Avatar
flash134
St. Jude Donor '05
I need to replace mine to just have not got around to it yet. got the part just need the motivation. The dash does not need to be removed. here is the forum link to DIY.
http://forums.corvetteforum.com/showthread.php?t=860333
To Hazard Light Switch Replacement
