3.73 gears available?
Old Apr 7, 2005 | 01:47 PM
1999 Vette's Avatar
1999 Vette
Default 3.73 gears available?
sources have said they aren't available....is that true?
Old Apr 7, 2005 | 02:30 PM
JohnnyO's Avatar
JohnnyO
I ordered the GETRAG factory 3.73 from Nate last fall. try
http://www.corvettegarage.com/catego...rive-Line.html
Old Apr 7, 2005 | 03:13 PM
Ego-Trip's Avatar
Ego-Trip
Senior Member
CI 5-6-7-8 Veteran
As of a couple of months ago I know there was a MAJOR shortage. Phil at DTE got in a bunch of them and they were all defective. I guess that Motive or whoever told him that the whole batch ended up being bad and there wouldnt be any coming in (from overseas?) for a couple of months.
If anyone has any up to date info it would be Phil...you might want to get in touch with him.
http://www.dynotech-eng.com/
***EDIT***
Here is the thread where Phil referenced the shortage.
http://forums.corvetteforum.com/show....php?t=1014157
Old Apr 7, 2005 | 03:41 PM
DTE Powertrain's Avatar
DTE Powertrain
Collections Hold
That is correct, there is a shortage of the MG 3.73 ratio gear sets due to the entire last run delivered from Italy being defective and completely unusable by any stretch. We, (nor MG) has any timeline on when the next run will arrive either, so the only way one can obtain a 3.73 gear set is if they found a set on a shelf somewhere from an old batch in the past.
Best Regards,
DTE
Old Apr 7, 2005 | 04:40 PM
Mike Mercury's Avatar
Mike Mercury
Getrag themselves made a 3.73 carrier - Sold through GM - but it's expensive.
I wonder if they (complete Getrag carriers) are still available?
To 3.73 gears available?
