Looking for Stock Z06 Alignment Specs
Old Apr 9, 2005 | 01:53 AM
ClarksZ06's Avatar
ClarksZ06
Default Looking for Stock Z06 Alignment Specs
Does anyone have a link where I can print off the stock alignment specs for my 02 Z. I just put on new tires and I want to make sure I don't get premature wear form my current alignment being off.
Thanks,
Clark
Old Apr 10, 2005 | 09:24 AM
Innovator's Avatar
Innovator
Notes Front Alignment Specifications All Front Individual Toe Serviced Preferred + 0.04
Tolerance +/- 0.10
All Front Sum Toe Serviced Preferred + 0.08
Tolerance +/- 0.20
All Steering Wheel Angle Serviced Preferred 0.0
+/-1.0
FE1 & FE3 Front Individual Caster Serviced Preferred + 7.4
Tolerance +/- 0.5
FE1 & FE3 Front Cross Caster Serviced Preferred Within +/- 0.5
Tolerance -
FE1 & FE3 Front Individual Camber Serviced Preferred - 0.20
Tolerance +/- 0.5
FE1 & FE3 Front Cross Camber Serviced Preferred Within +/-0.5
Tolerance -
FE4 (Z06) Front Individual Caster Serviced Preferred + 6.9
Tolerance +/- 0.5
FE4 (Z06) Front Cross Caster Serviced Preferred Within +/- 0.5
Tolerance -
FE4 (Z06) Front Individual Camber Serviced Preferred - 0.70
Tolerance +/- 0.5
FE4 (Z06) Front Cross Camber Serviced Preferred Within +/- 0.5
Tolerance -
Rear Alignment Specifications All Rear Individual Toe Serviced Preferred - 0.01
Tolerance +/- 0.10
All Rear Sum Toe Serviced Preferred - 0.02
Tolerance +/- 0.20
All Rear Thrust Angle Serviced Preferred 0.0
Tolerance +/-0.10
FE1 & FE3 Rear Individual Camber Serviced Preferred -0.18
Tolerance +/-0.5
FE1 & FE3 Rear Cross Camber Serviced Preferred within +/-0.5
Tolerance -
FE4 (Z06) Rear Individual Camber Serviced Preferred -0.68
Tolerance +/-0.5
FE4 (Z06) Rear Cross Camber Serviced Preferred within +/- 0.5
Tolerance -
Z Trim Height FE1 Service Preferred 44 mm (1.73 in)
Tolerance 1.48-1.98 in
FFE 3 Service Preferred 43 mm (1.69 in)
Tolerance 1.44 -1.94 in
FE 4 (Zo6) Service Preferred 49 mm (1.93 in)
Tolerance 1.88-2.18 in
D Trim Height FE1 Service Preferred 108 mm (4.253 in)
Tolerance 4.0-4.50 in
FFE 3 Service Preferred 107 mm (4.21 in)
Tolerance 3.98-4.46 in
FE 4 (Zo6) Service Preferred 104 mm (4.09 in)
Tolerance 3.84-4.35 in.
J Trim Height FE1 Service Preferred 153 mm (6.02 in)
Tolerance 5.77-6.26 in
FFE 3 Service Preferred 152 mm (5.98 in)
Tolerance 5.73-6.24 in
FE 4 (Zo6) Service Preferred 152 mm (5.98 in)
K Trim Height FE1 Service Preferred 158 mm (6.22 in)
Tolerance 5.97-6.47 in
FFE 3 Service Preferred 157 mm (6.18 in)
Tolerance 5.93-6.43 in
Old Apr 11, 2005 | 08:40 AM
ClarksZ06's Avatar
ClarksZ06
Thank you very much.
Old Apr 11, 2005 | 09:00 AM
EHS's Avatar
EHS
If you are worried about premature tire wear, you may want to back off on the front negative camber setting about 1/2 way.
To Looking for Stock Z06 Alignment Specs
