Need Harness Info....
Old Apr 10, 2005 | 10:39 AM
Phil97SVT's Avatar
Phil97SVT
Default Need Harness Info....
I need to add a safety harness to my car after being kicked out friday. What brand should I get and what mounting hardware do I need? I already have a chromemoly tab on my cage for the rear strap.
Phil
Old Apr 10, 2005 | 01:13 PM
leaftye's Avatar
leaftye
TeamTech harnesses are comfy and relatively easy to put on, as well as having a pass-thru in the anti-sub strap for your nuts if you wreck. The Willans 6-point is a true six point, with properly mounted sub straps to stop your hips from moving forward without smashing your nuts to do it, but the Willans will take a little longer to put on, and doesn't have the comfy pads that the TeamTech has. Both are >$300.
