head lights dim while braking
Old Apr 11, 2005 | 08:32 PM
corvettefreak16's Avatar
corvettefreak16
Default head lights dim while braking
like i said my head lights dim when i go to brake. Whats causing this? could it be my alternator going bad? any help would be apreciated. thanks in advance.
Caleb
Old Apr 11, 2005 | 09:05 PM
EHS's Avatar
EHS
Hesus, Caleb.
That's some serious "stuff."
Old Apr 11, 2005 | 09:12 PM
happa's Avatar
happa
Ive had the same problem and come to find out after many many hours of research. My fuse was loose. So I took them all out under the dash and in the engine bay, and pushed them in tightly and of course made sure nun are blown. If not check your battery cables. If not may be alternator. Good Luck
Old Apr 11, 2005 | 09:21 PM
EHS's Avatar
EHS
So, there's a "fuse loose in the hius?"
(It's a PBS thing).
Old Apr 11, 2005 | 09:23 PM
2pedala's Avatar
2pedala
Default you wont belive this but
my car was doing same thing an then got to dimmin when auto trans drew power to shift. it was battery itself. even though started great no hesitate. if you dont have a good farley new battery or can swap one for trial, beats all i ever saw think these cars are amp hungry
Old Apr 11, 2005 | 09:27 PM
Special K's Avatar
Special K
(It's a PBS thing).
Who said this isn't a fun place to be?
Old Apr 11, 2005 | 09:29 PM
Special K's Avatar
Special K
I never heard of a Farley battery. Is this something new?
Old Apr 11, 2005 | 09:31 PM
corvettefreak16
Its probably the battery. I had been having problems with it starting before so i took it out and cleand and the terminals and connections and have not since had a problem.
To be sure thought i will go over all the fuses to make sure.
thanks
Old Apr 11, 2005 | 09:53 PM
shaneotool's Avatar
shaneotool
Mine is even worse - The lights will also dim for a second every now and then for no reason. I turned my info thing on "volts" and it will go from 14 down into the 12's then back up. That's when the light dims. hopefully a new battery will fix it.
Old Apr 11, 2005 | 11:18 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Here we go.
To head lights dim while braking
