Neutral safety switch?
Old Apr 12, 2005 | 12:24 PM
wreakhavoc's Avatar
wreakhavoc
Default Neutral safety switch?
Today just out of the blue my car wouldn't start after driving it and making about four stops. Turned the key and absolutely nothing- no sounds, nothing. Luckily I was just a mile from home so I walked home and got my truck, got back to the car and it started right up as if nothing was wrong. Battery is only 7 months old, can't find any info on neutral safety switch in the service manual.
(99 with manual trans.)
Now I need to walk back and get my truck...
Old Apr 12, 2005 | 01:43 PM
wreakhavoc's Avatar
wreakhavoc
After searching through older posts here I came to the conclusion that it was probably just my key and/or key hole in the dash needed cleaning. The "security" warning light was flashing and it apparently disables starting for 5 minutes- that explains why it started right up 20 minutes later. Still curious about the neutral safety switch location though in case that problem ever arises.
Old Apr 12, 2005 | 01:46 PM
DRR's Avatar
DRR
My guess is its on the clutch pedal linkage. It also turns off the cruise control if you tap the clutch. Doug
To Neutral safety switch?
