C5 5 point harness install question...
Old Apr 14, 2005 | 10:45 PM
Phil97SVT's Avatar
Phil97SVT
Default C5 5 point harness install question...
Where are you guys bolting the left lap belt on the driver side?
Phil
Old Apr 14, 2005 | 11:46 PM
yellow01's Avatar
yellow01
How are you mounting your belts to begin with?
I use the Brey-Krauss mounts purchased from http://www.ogracing.com/eshop/home.asp?categ=220 and they work great. The tunnel side mounts to the seat rail between the rail and the existing seat belt mount (which is retained) and the outboard mount sits underneath the door sill plastic. You must slightly enlarge the slot the seatbelt travels through but it's easy and very clean.
Hope this helps.
Old Apr 15, 2005 | 01:15 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Hope this helps.
This is what I'm using now and they are awesome.
You'll also need to get a couple of these for your lap belt and sub strap: Snap in clip
I can't remember where I got mine but they were cheaper than this and all I got was the snap in restraint, I didn't get the eyebolt and nut.
Old Apr 15, 2005 | 08:24 AM
kromberg's Avatar
kromberg
I wish there was something a little less pricy. Has anyone fabricated an alterniative?
Keith
Old Apr 15, 2005 | 08:33 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
BK here as well..caught them on sale
Fits right under the stock seat belt retractor
Old Apr 15, 2005 | 06:22 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Keith
These make for an extremely clean install and include the brackets for both seats, I thought they were a little pricey as well until I found out that it came with 4 brackets
Old Apr 15, 2005 | 08:04 PM
AU N EGL's Avatar
AU N EGL
And they are proven material. not a "well give this a try"
To C5 5 point harness install question...
