Do these repair costs seem HIGH?
Old Apr 18, 2005 | 10:48 PM
  #61
VLVETTE's Avatar
VLVETTE
Originally Posted by runamuk
The oil change is about right
The battery can be replaced with an 8mm wrench and a 10mm socket in about 5 minutes if you have the replacement battery and the only thing you will have to do is reset the time on your radio.
Here is a link to the front airdams "Ken Fichtner Chevrolet" the air dams are on page 6 and only cost $56.00 in parts and take less than 20 minutes to install.
I had my transmission fluid flushed at the local dealership for $125 and there was no discount involved so your definitely getting ripped on that one.
$750 for pads fluid and bleeding you've got to be kidding me.
Is the cracked piece the plastic covering? because thats only held on with 4 10mm bolts and costs around $50 with a 10 minute installation time.
Take your car someplace else the only thing thats reasonable in their quote is the oil change.
Old Apr 18, 2005 | 10:53 PM
  #62
NSTG8R's Avatar
NSTG8R
Originally Posted by bgames
Here are the estimates I received from a local Vette specialist.
oil change & filter $73.00
battery replacement, with 6 year AC Delco $145.00
replace air dams & deflector $205.00
replace transmission fluids (on 29,000 mile car?) $215.00
new brake pads, fluid and bleeding $750.00
replace cracked upper radiator support? $145.00
not to mention they appear to be charging me $188 for the inspection/diagnosis.
Thoughts? Advice?
otehrwise pretty much in line .. cost me about $350 (total) when i did my brake rotors, pads, and fluid (and i used racing fluid) and diagnositic stuff should be deleted once they do the work .. but i also did all the work myself. so no labor costs.
edit: after reading another post and finding he's only resurfacing the rotors .. this guy is a scam artist. You came to teh right place, corvette forum .. we'll set you straight
.. go back and tell him you know he's full of it.
Old Apr 18, 2005 | 11:19 PM
  #63
countslav's Avatar
countslav
Originally Posted by 84zz4vette
Better not be just pads alone......at that price it should include some nice and pretty drilled/slotted rotors....
Old Apr 19, 2005 | 04:51 PM
  #64
GR8-LIFE's Avatar
GR8-LIFE
[QUOTE=Ruby6spd]
Originally Posted by MARK's_C5TT
"dealer" - thats your problem. I buy my own synthetic (7 gal at $4
per gal).
QUOTE
That is some cheap oil - what type are you using?
Mobil SuperSythetic 15/50. Always have used it, always will. You can get it at COSCO for that price and sometimes Walmart for $4.25. PEPBOYS was running an even better special, buy 1 get one free if you buy some calendar for $1.00. I know lots of forum members stocked up on this stuff big time. Unfortunately, I missed out.
Old Apr 19, 2005 | 05:05 PM
  #65
jdetar's Avatar
jdetar
Actually I just bought some from Pep Boys. My pep boys still has some calendar's and do that deal. Check and yours still may!
Old Apr 19, 2005 | 06:50 PM
  #66
2KVetteMan's Avatar
2KVetteMan
Sticking to the subject.
The oil change about right.
EVerything else besides the brakes seems correct at $94.00 for an hourly charge.
The brakes that is crazy honestly. From my experience I had bad rotors when I got my corvette. Took it to the dealer and had the front pads changed and rotors turned $250.00 later and my rotors went bad in 2 months. WARPED!!
Never ever!!! will I turn the rotors, especially when you can buy them for $27.00 at NAPA as stated above. They charge you more for turning them then getting new ones.
Find a buddy or someone else to install your brake pads and rotors.
If you are mechanically inclined we can help you here on the board. Changing the rotors and brakes is cake.
