DIC tire pressure
Old Apr 15, 2005 | 10:03 PM
Jserman's Avatar
Jserman
Default DIC tire pressure
I noticed that my DIC was saying my rear tire where a little low 30PSI so I got out the compressor and filled them up to around 38PSI according to my tire gauge but my DIC is still reading 30.. what the hell.. how often does the sensor get the pressure reading or what???
Old Apr 15, 2005 | 10:15 PM
army2000's Avatar
army2000
St. Jude Donor '11
your TP should be at 30psi. In this case I wouldn't care what the TPS says. Fill your tires up and check them with a regular TP gauge. If it still reads low, then retrain your TPS. Hope this helps.
Old Apr 15, 2005 | 10:30 PM
Jserman's Avatar
Jserman
at 30 PSI my tires look low and my back end is all over the place at 35 or so it is a lot more stable...
and how do I retrain my TPS????
Old Apr 15, 2005 | 10:34 PM
army2000's Avatar
army2000
St. Jude Donor '11
https://www.corvetteforum.com/techti...D=77&TopicID=1
are you running the factory wheels and tires????
Old Apr 15, 2005 | 10:37 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Have you driven the car since filling the tire?
The DIC display isn't in real time. The sensors update about once a minute when moving, but only about once an hour when idle (parked). Take your car out for a short drive, and you should see the updated psi displayed soon.
Old Apr 15, 2005 | 11:44 PM
Jserman's Avatar
Jserman
Yes.. I drove my car to work after filling them up and the right went up to 33 and the left stayed at 30.. and my pressure gauage was reading about 38
Old Apr 16, 2005 | 12:01 AM
army2000's Avatar
army2000
St. Jude Donor '11
IMO, I would set the cold TP to 30 using a standard TP gauge and then retrain the TPS. If that does not work, I would have the car looked at. Your rear end should not be swaying with the AHS at 30psi. It could be a tire problem. Hope this helps.
Old Apr 16, 2005 | 12:03 AM
servohead's Avatar
servohead
Same problem here, they all seem to read a few PSI too low. I set mine all to exactly 30 cold and they always read lower than that even though I know for a fact that my gauge is correct. I'm not going to worry about it until my sensors go bad...
Old Apr 16, 2005 | 02:45 AM
Jserman's Avatar
Jserman
I could care less if the sensor is there or not.. I would get rid of them if I wouldn't get and error on my DIC...
Old Apr 16, 2005 | 10:41 AM
coast7's Avatar
coast7
Jserman,
You may want to rethink that position. The TPS system was really not designed to tell us the TP in lieu of using a TP gauge; but to warn us when there is a significant drop in TP. We carry no spare, we drive aggressively. Its nice to have a early warning system, that's what it's for. Our tires and wheels are expensive...prudent use of the TPS system may save us money and more...
JMHO
Old Apr 16, 2005 | 11:00 AM
DidntSettle's Avatar
DidntSettle
From: Manchester - Political correctness is tyranny with manners.
I didn't think the TPS's worked at all unless the car was moving above 24mph?
Old Apr 16, 2005 | 02:27 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Last time I had an oil change the garage set the tire pressure to 31psi. I drive away and DIC said 31. That sounds like a bad hand gauge to me.
Old Apr 16, 2005 | 11:01 PM
SPDaylightFan's Avatar
SPDaylightFan
Default On the money
My sensors are right on the money .. so much so that I trust what they DIC says. Everytime I have checked them against an expensive guage ... they have agreed.
Dave
Old Apr 16, 2005 | 11:09 PM
Jserman's Avatar
Jserman
well after 2 days of driving my DIC finally caught up and is reading right know...
To DIC tire pressure
