Help with Spec clutch install please! Shim or not?
Old Apr 15, 2005 | 10:54 PM
Drako's Avatar
Drako
Default Help with Spec clutch install please! Shim or not?
Hi guys,
I am reading that most of the Fbody guys require the green or metal shim to get good engagement point using the stock master cylinder. I have also read some posts that the Corvette does not require the shim whereas the fbody does?
I am using a new fresh flywheel and new updated master/slave cylinders with drill mods done. This is for a Spec 4 clutch
Does anyone have any advice for me here about the shim, I do not have the shim to install and may have to put off my clutch re-and-re planned for the weekend in order to get one.
Thanks!
Old Apr 16, 2005 | 12:08 AM
C5-JIM's Avatar
C5-JIM
Only On F/body Cars
Jim
Old Apr 16, 2005 | 03:52 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
My Spec III said shim was only for F bods as well.
Old Apr 16, 2005 | 06:28 PM
C54DAZ's Avatar
C54DAZ
I used the shim after talking with the tech at spec and several other people including Reese at Mti. He had an article in vette magazine about the spec install, I would use the shim you will be happier with the way the pedal ingauges. MIne feels great and you dont have to push the pedal all the way to the floor. Iv talked to others who who ended up putting the shim in a second time cause they didnt like the way it felt. Call around and ask the pros.. Mine was a spec II though!!
To Help with Spec clutch install please! Shim or not?
