Flyin'Brian..raptor install inst.
Old Apr 15, 2005 | 07:17 PM
3Vettes@Home's Avatar
3Vettes@Home
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Default Flyin'Brian..raptor install inst.
does anyone know the link to full install inst. from Brian? I'm trying to install before the Birthday Bash...Thanks!
Old Apr 15, 2005 | 09:49 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Here you go.
http://forums.corvetteforum.com/show...ght&forum_id=1
Old Apr 15, 2005 | 09:50 PM
3Vettes@Home
Cruise-In V Veteran
ttt...I will check back in the morning....thanks
Old Apr 15, 2005 | 09:52 PM
3Vettes@Home
Cruise-In V Veteran
Originally Posted by Z06-JIM
Thanks! that helps, but I also was wanting to know what "hot" wire is to be used?
Old Apr 15, 2005 | 10:05 PM
Z06-JIM's Avatar
Z06-JIM
I found a switched hot wire in the same area under the drivers side dash going over to the passenger side foot well. It was a redish/orange color. There's a few other options you could also use such as the traction control switch hot wire under the center console or the fog light switched hot wire, which I think is a brown & white wire.
Old Apr 15, 2005 | 10:47 PM
Blueyednd's Avatar
Blueyednd
St. Jude Donor '05
I picked up power from the big orange wire on the left side of the ignition harness (switched power).
Old Apr 16, 2005 | 08:42 AM
3Vettes@Home
Cruise-In V Veteran
Thanks guys!
Old Apr 16, 2005 | 06:41 PM
C54DAZ's Avatar
C54DAZ
All the wires you need are in that same loom including hot and ground.
http://home.comcast.net/~c54daz/Skipshift.html
To Flyin'Brian..raptor install inst.
