Jack for Flat Kit?
Old Apr 16, 2005 | 09:05 PM
Rodzilla's Avatar
Rodzilla
Default Jack for Flat Kit?
What kind of jack do you use in your flat tire kit? Where did you purchase?
Old Apr 16, 2005 | 09:08 PM
Maniac's Avatar
Maniac
Old Apr 16, 2005 | 09:15 PM
JChrisF's Avatar
JChrisF
And how about a good air compressor the kit too?
Old Apr 16, 2005 | 09:20 PM
JackTsDBG's Avatar
JackTsDBG
There's a low profile Mercedes-Benz scissors jack that works very well and takes little space. There's a Forum member in Germany that has been helping people out with these.
Old Apr 16, 2005 | 10:23 PM
RCK1999's Avatar
RCK1999
compact scissors jack "modded" with metal jacking puck built-in.
Old Apr 16, 2005 | 11:14 PM
Shylor's Avatar
Shylor
I like this one, it's small and lightweight.
Old Apr 16, 2005 | 11:29 PM
SPD KILZ's Avatar
SPD KILZ
Where can i get one of thoes!? That is awesome, how stable is it though? My car is slammed and i have no way of getting it up on the side of the road but that might work.
Old Apr 16, 2005 | 11:36 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
It will definitely work I have one and they are great. Go to your local Mercedes Benz dealer and they can get you one. They put them in their sports cars.
Old Apr 16, 2005 | 11:43 PM
Admiral Fairway's Avatar
Admiral Fairway
RCK1999 where did you get your scissors jack at?
Old Apr 17, 2005 | 12:20 AM
Armadillo's Avatar
Armadillo
Unless you're in a hurry, don't waste the money at a Mercedes dealer. Order one from the member in Germany for $50 (that was the price when I got mine). Do a search to find the thread with this item. I believe his name is Frederik.
Old Apr 17, 2005 | 12:26 AM
3RD-INF's Avatar
3RD-INF
Go to the BMW dealer. My boss gave me one for a gift she bought at her BMW dealership. I'm not sure but about $40. It's just like the Benz jack.
Old Apr 17, 2005 | 04:18 AM
Antvette's Avatar
Antvette
Veteran: Marine Corps
NO!!! Go on Ebay. I got an entire kit, jack and all the other tire changing kit from a VW. It's the same jack as that. I got it all for 43 shipped.
Old Apr 17, 2005 | 06:33 AM
EMDExpress's Avatar
EMDExpress
Be sure to buy an inflator that is high volume/low pressure model. Also get an all metal tooled plug kit.
Old Apr 17, 2005 | 08:44 AM
Maniac's Avatar
Maniac
Looks like this scissors jack would work. It's one of the few I've found that is low enough ( 4 5/16" ) to fit under a C5 that had a flat tire. Since it's for emegencies only, does it have to have a "puck"?
http://www.usahardware.com/inet/shop..._fu/t_9446.htm
Also, this looks like a good repair kit.
http://www.safetyseal.com/store/autokits.htm
Found this inflator.
http://cgi.ebay.com/ws/eBayISAPI.dll...372704335&rd=1
If anyone has names of products they're using with success, maybe you cn post them. It would sure help those of us that are putting a tire repair kit together!
Old Apr 17, 2005 | 09:27 AM
RCK1999's Avatar
RCK1999
Good morning. It is a 1.5 ton jack I found at my local Northern Tools store for $15. It came with a small bracket riveted on the top. I ground the rivet off to remove the bracket and attached an o-ring and washers (from Home Depot for about $2) to create the jacking puck. Works great, and is quite stable. I looked at the small jack from the member in Germany. I almost got it, but it sure looks unstable.
Old Apr 17, 2005 | 01:16 PM
Maniac's Avatar
Maniac
Rick, is this the jack? It's a 1-ton, but that's all I could find in the Northern catalog. It does have a perfect lifting range, though! If it's not a bother, did you use 1 1/2 " fender washers? Thanks!!!
http://www.northerntool.com/webapp/w...53&R=200305253
I found this one as well and it looks closer to yours!
http://www.autosupplyusa.com/lar15tonscis.html
Old Apr 17, 2005 | 01:37 PM
RCK1999's Avatar
RCK1999
The second one you found looks exactly like the one I got at Northern Tools (it was a year or so ago. I guess they change styles occasionally). It even has the wierd bracket on the top. The bracket is just attached with one rivet, so it comes off easily. The price looks good as well! The eye bolt I used is 1" in diameter. The fender washers are 1 3/4". Your 1 1/2" would work just fine.
To Jack for Flat Kit?
Old Apr 17, 2005 | 01:47 PM
Maniac's Avatar
Maniac
Thanks, Rick! I just ordered it!
Old Apr 17, 2005 | 04:01 PM
TEXHAWK0's Avatar
TEXHAWK0
I have the German jack and it does tend to try to rotate as you crank it until it get some load on it. The nylon head does not fit into a slot as intended on the Mercedes, and does not create enough friction to keep it from rotating.
I got an extra aluminum jacking puck and milled a slot in it to fit the nylon head of the jack, and now it works fine for emergencies. The jacking puck installs in the frame slot as normal so it cannot slide, and the head of the jack fits perfectly into the slot in the puck.
Old Apr 17, 2005 | 05:51 PM
Maniac's Avatar
Maniac
RCK, when you get a chance could you post a pic of your jack so we can get an idea of what you did with the eye-bolt? Many thanks for all your help!
