Front wheel "Drag" set-up....
What are the choices? Looking for some input....A buddy of mine has some 5.5" rims (don't remember the brand), and it looks like he could have went even smaller in width (which would weigh even less) based on how the tire fits on the rim.
Any info is much appreciated...
Thanks,
Tony M.
I was at Famoso Friday night. Just put on a new set of 12x26x16 M&H full race slicks. Best 60' with ET Streets was 1.52 did two 1.46 Friday.
appreciate your info
Keith
Thanks,
Tony M.
http://www.real-performance-motorsports.com/index.cfm
(972) 434-2151
custom setups for the front of our c5's
(972) 434-2151
custom setups for the front of out c5's
Keith
The tires are on centerline 10x16 I forget the off set but the ET streets didn't stick out at all. The 12x26x16 M&H stick out about an inch and don't rub at all.
Let me tell you the ET Streets can't compare at all to these M&H's. All I do is a burn out in the water box, as soon as I see a little smoke let off the brake, keep RPM about 5000, let the car ease out till the tires grab, and boy do the grab, and your good to go. I run about 14LB cold.
Don't need tubes, work just like the ET streets.
Those Firestone front tires are " classic car tires" call Firestone and ask them. I know alot of guys use them because that was all you could get, but M&H now makes a 16" front runner that is made for racing.
I know I must sound like I work for M&H, but I don't, I just know how hard it is to find tires that fit the vettes and work good. I just want to share what I found and works better than any thing else.
I get mine here in Bakersfield from John Hashim he has the best price I have found and will ship any where. PH# 661-324-4773
Thanks for all your input....
Looks like I've learned a few things in the last day or so....I'm screwed trying to run CCW's due to the aftermarket Wilwood brake set-up I have (the calipers have opposing pistons and stick farther out which interferes with the rim), and NOBODY has a 17" front runner to go on a modified 17" stock Z06 rim.
I think what I might end up doing is to purchase two 17 X 9.5 Z06 chrome replica's (to match the rims my ET Street are on), and have them modified (narrowed) to say 6" in width and then run a very small 205/45 ZR17 radial. I like the fact it would be a Z-rated tire for the high speed blasts, and the combination should weigh close to a CCW 16" set-up if my information is right. Does anyone have the exact weight of the 16" Firestone CCW set-up??....I was told about 32 lbs or so. The only couple of negatives with my plan is cost, and the fact its still not a bias ply and might still wander a bit, but I think a much smaller tire than I'm currently running (285/35 18) would want to "steer" the car a little less and be more stable than I am currently experiencing. Also, I will probably have to disengage the traction control at all times as the tire is only 24.4" tall, but that doesn't seem like a big deal....I usually run that way anyway. Plus, I'm hoping the additional slight rake and being lower to the ground in the front might have a benefit with some "aero" on the big end.
All this for a tenth....maybe....LOL I must be crazy. What I do like about this plan (assuming all works out) is the car will still look VERY stealthy with the factory Z06 rims front and rear....I kinda like that.
Any more input before I get sucked in this direction?
Sounds like an interesting idea. I would think(positive) the CCW race wheel would be a couple of pounds lighter. Yes, rake is good front to back. I can't remember to best racing spec's for that at the moment. Thining an 1-2."
I would have one Z06 set for the dragstrip and one set for the street.
If you have to ask...Yes, you are nuts. Unfortunately, I too, suffer from the mental issues. Thinking about dumping 10K+ plus on my next tire and rim combo.
Keith
john@mandhtires.com
I think I can come pretty close with my gameplan laid out above. If my modified stock rims come in close to 13-14lbs I'm golden!
