EndLinks
Old Apr 18, 2005 | 07:04 PM
canadianguy's Avatar
canadianguy
Default EndLinks
Does anyone know if gm makes the improved endlinks for the front? Or do you have to get them aftermarket?
Old Apr 18, 2005 | 07:05 PM
yellow01's Avatar
yellow01
two questions -
endlinks as in swaybar?
which do you have now?
Older C5s had plastic, newer ones have metal endlinks, so if you have the plastic ones, yes you can get better ones from GM.
Other than that there should not be any need for anything else with a stock bar.
Old Apr 18, 2005 | 07:09 PM
canadianguy
Originally Posted by yellow01
two questions -
1. yes
2.metal
The reason I ask is the that both are stripped, I can't even tighten the thing because the tourque slot is stripped. It happened with relatively easy, I thought it was because they were cheap, thought I could get an improved set.
Old Apr 18, 2005 | 08:48 PM
jimcork1's Avatar
jimcork1
Default End links
I just replaced the end links.
END LINKS ARE 10351954 OR ECKLERS 45361 A24-7-04
These are the metal upgrades vs. the fiber origional. This is an upgrade and I have already installed them. 99 Nassau Blue
To EndLinks
