What does TCS code C1214 mean????
Old Apr 19, 2005 | 09:10 PM
Sho-nuff's Avatar
Sho-nuff
From: When I say who is the masta you gotsta say Shonuff
Default What does TCS code C1214 mean????
C1214 Sol Valve Relay Contact or Coil CKT Open
What does this mean?
It came up this afternoon when I fired my car up.
Thanks.
02 Z06
Old Apr 20, 2005 | 01:57 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
http://www.stengel.net/diccodes.htm
Old Apr 20, 2005 | 02:00 AM
phils C5 vette
my bad. you already knew what the code meant.
Oh well a good web page for guys to save to look up codes
Old Apr 21, 2005 | 04:53 PM
rockrz's Avatar
rockrz
I'm gonna give ya a bump.
My vert is displaying this code also.
Already checked the blinker fluid and muffler belts.
Old Apr 21, 2005 | 10:32 PM
purrvert's Avatar
purrvert
Thanks.
02 Z06
Means your ABS/TCS are disabled. Check fuse #53 20 amp under hood fuse box, check ground 108. Any time you turn on your key this relay in the EBCM should energize, if it senses less than 8 volts and the ignition voltage is greater than 10.5 the DTC sets. 50 igniton cycles without problem will reset the code, or scan tool can reset. Good luck.
Old Apr 28, 2005 | 03:46 PM
Sho-nuff's Avatar
Sho-nuff
27975 Internal Malfunction in BPMV/EBCM
Part # 12216561 Module $935.72
Part # 10343432 Valve $1645.92
Part # 12377967 Fluid $7.10
Labor $373.75
Total $2962.49
To What does TCS code C1214 mean????
