Stop thinking about it and GET THEM! It's like a different car now...beastly acceleration, the front end feels like its lifting off the ground! And 1-2 shifts are neck snapping! Best mod yet!
And for those contemplating doing the install themselves...I say go for that too. Dope's write up made the install a breeze! Thanks Dope!
What is there to compromise by going to a 4.10? At 80 mph in 6th gear your Coupe or Convertible is only turning 2.150 rpms. I still get over 28 mph in my modified Z06 with them and the MN6 trans.
I installed 4.10's and changed to 3.72. If you got alot of torque and hp, first and second gears are totally useless on the street. You need ET Streets for the track and even then 4.10's cause the fifth gear shift problem: An extra shift to a poor pulling gear. Use your hp curve, your rev. limit, and trap speed to calculate the better gear ratio. I, and other forum members, like to finish the quarter at the peak of the hp curve in fourth gear. Most high power C5's (>600 hp) use the stock gear ratio, check the mods of their cars. Nothing wrong with 4.10's if they are a good marriage to your expectations.
Theres NO WAY I could have 4.10's
I was considering 3.90's but thats prolly to much gear as well. What do you think?? I'm over 700RWHP.
Reason: grammar
At 700rwhp you should be good with the stock 3.42's...that is alot of power. I'm running an ARE H/C with full bolt ons and the 4.10's were a perfect match.
About the traction...I'm running 305/35/18 nitto r's on the rear so traction is decent in warmer weather. This is at about 410rwhp/385rwtq.
And for those thinking about doing the install...here is the write-up Dope's Install Guide
Your right where I am and my 4.10's and DTE brace go in next week...cant wait for the next track day. Whats your 1/4 witht he 4.10's?
